88-91 B16a1 is a 00 Civic Will it work??????????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic32958 »</TD></TR><TR><TD CLASS="quote">I got a 00 civic need to know if an 88-91 civic DOHC motor will fit with the same mounts or do i need special mounts??</TD></TR></TABLE>
it will work with 99-00 ciovic si rear L bracket mount, lower tranny mount and lower driver side mount
the rest you can use off ur 00 civic
also you will need to change all your obd0 components into obd2b
dist
ecu
starter
alt
are some of the things dat u will have to change
why do you wanna oput an old *** engine in ur car? btw it wont pass smog
dist
ecu
starter
alt
