Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What oil are you using?
Old Oct 7, 2001 | 08:24 PM
Rob Dizzle's Avatar
Default What oil are you using?
Im running Mobil 1 synthetic
I am going to be going to a track day in about a month. Should I switch to some red line synthetic?
Old Oct 8, 2001 | 03:59 AM
Todd Reid's Avatar
Default Re: What oil are you using? (bob46802)
I have always used Mobil 1 5w-30 synthetic in all my Hondas and it has never let me down. It is great stuff!
Old Oct 8, 2001 | 05:38 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
I burn so much oil, it would be silly to use anything but el cheapo 10w30...
-Chris, who wishes he bought oil stock a couple of years ago...
Old Oct 8, 2001 | 06:52 AM
SOHCArchangel's Avatar
Default Re: What oil are you using? (madhatter)
i use the mobil 5-30, b/c it burns easily and wont sludge up, hate it b/c it burns too easily, love redline, but too expensive, want to keep using synthetic, is there a moderately priced one that wont burn as easily (my freind in his 99 lude has the same prob)
Old Oct 8, 2001 | 06:54 AM
r2x's Avatar
r2x
Default Re: What oil are you using? (SOHCkordVTEC)
I run 15w50 (in my Miata).
Speaking of... she gets an oil change this week prior to VIR this weekend.
Old Oct 8, 2001 | 07:09 AM
B18CXr's Avatar
10-30 Mobil one
Old Oct 8, 2001 | 07:44 AM
BryanSprinkel's Avatar
Default Re: What oil are you using? (B18CXr)
5-30 mobil 1
Bryan
Old Oct 8, 2001 | 08:00 AM
XR4racer's Avatar
10-30 Mobil one
Yep.
Old Oct 8, 2001 | 10:27 AM
Honda318dx's Avatar
Default Re: What oil are you using? (XR4racer)
Well, this "new" motor will get mobil 1 5w-30, the old (rip) motor went through a quart of mobil 1 every 2 sessions... Non synthetic mobil didn't burn as much, only about 1.5 quarts a day
Old Oct 8, 2001 | 10:44 AM
WRXRacer111's Avatar
Default Re: What oil are you using? (Honda318dx)
since Corey has a top-secret oil-injection system, almost as secret as the AGSM 5 Spec-Q Gold-edition...
Old Oct 8, 2001 | 01:23 PM
DFauth's Avatar
New User
I've had Hondas in the past that would burn some oil when I used Mobil 1. I started using Valvoline Synthetic 5-30 and have never had the problem again.
Old Oct 8, 2001 | 02:08 PM
Willard's Avatar
10-30 Mobil one
Yes, here also.
Less consumption was observed when I switched from 5W-30 to 10W-30.
Will
-who *just* changed his oil in preparation for VIR this weekend.
-who also found Mobil 1 on sale at BJ's for $3.89/qt.
Old Oct 8, 2001 | 05:28 PM
4doorH22's Avatar
Default Re: What oil are you using? (Willard)
Mobil 1 of course.
Honda really only recommends 5W30 up to 95 degrees F, hence I use 10W30 in the hottest summer months.
Old Oct 8, 2001 | 05:45 PM
krshultz's Avatar
Default Re: What oil are you using? (DFauth)
Probably whatever Fauth suggests is A Good Thing since he's a national champion (good to have you here BTW David).
Personally I put 5W30 Mobil 1 in the car - and have done so since it had 5000 miles on it. It does smoke on lifts and shifts (valve guides I'm told) but has 6-7% leakdown. Not bad for 4 years of autocrossing and 20 or so track weekends.
--rice
Old Oct 8, 2001 | 09:08 PM
civicrr's Avatar
Default Re: What oil are you using? (krshultz)
The manuals I have say that 5W-30 is the prefered oil for all temps. It also states that "You may use 10W-30 if the temp. in your area never goes below 20*. 5W & 10W are the winter rates of the multi oils. 30 is the viscosity when it warms up. Using 10W-30 instead of 5W-30 doesn't give you any more high temp. protection.
Old Oct 9, 2001 | 04:02 PM
BplantCivic's Avatar
Wow. I guess I'm the only one using Leading Edge motor oil....
Old Oct 11, 2001 | 12:44 AM
ToneyTigre's Avatar
New User
im a Castrol Syntec man!
deerman2701
14
Jan 11, 2012 07:58 AM
SiYouLater
Acura TSX
Jul 27, 2007 02:36 PM
floatfisher
May 28, 2006 11:46 AM
mickey513
Apr 7, 2002 01:24 PM
Mike D
Jun 23, 2001 07:26 PM
