fiber images hood wont close...
Old Feb 6, 2004 | 06:50 PM
t0ekn3e's Avatar
Default fiber images hood wont close...
i just got a fiber images hood and it wont seem to close i seems like something is blocking it but i dont see what ny suggestions or ideas?
Old Feb 6, 2004 | 06:53 PM
Ricey McRicerton's Avatar
Default Re: fiber images hood wont close... (t0ekn3e)
When swapping from a JDMShit.com hood back to an OEM hood we did'nt have the hood far enough forward and part of the latch was hitting the underside of the hood, not allowing it to close. I suggest taking out your grille (if it's on an EK) and watching to see what's keeping it from closing.
kKdARIAN's Avatar
Vice President/CEO
how about some pictures to better help us help you...
do you have access to a digital camera... that would help Alot.
Old Feb 6, 2004 | 07:07 PM
pdiggitydogg's Avatar
can you tell what area of the hood is hanging up?
Old Feb 6, 2004 | 07:08 PM
Grip's Avatar
Default Re: (pdiggitydogg)
so align your hood..its that simple
Old Feb 6, 2004 | 07:13 PM
not necessarily
Old Feb 6, 2004 | 07:45 PM
Discosteak's Avatar
my stocker sometimes wont shut simply because sometimes the release cable binds i usually just have to put my finger in the latch and push down(i know that sounds kinda vague but its honestly the best way i can describe it)
edit : come to think of it its not a stock hood its a certifit
Old Feb 6, 2004 | 08:03 PM
t0ekn3e's Avatar
i will try to get a picture in the morning
Old Feb 6, 2004 | 08:10 PM
Grip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">not necessarily</TD></TR></TABLE>
ok its one of three things
1..hood is not aligned properly to strike latch
2..hood is hitting the valve cover causing the hood not to reach the latch
3..latch is stuck half closed causing the hood not strike latch properly
Old Feb 7, 2004 | 11:28 AM
t0ekn3e's Avatar
heres a picture of the gap on both sides and about how far it goes down but wont close.
Old Feb 7, 2004 | 11:33 AM
turbo_ef9's Avatar
Default Re: (t0ekn3e)
my hood was like that too.. i had to like look straight down on it, push from there to close...
Old Feb 7, 2004 | 11:42 AM
t0ekn3e's Avatar
just tried that and it wouldnt work.
Old Feb 7, 2004 | 11:55 AM
oldB18EF's Avatar
it may actually be the latch, when i had my CF hood on my EG i had ordered from Tornactive it turned out really shitty and I had to cut metal out of the part with the latch on the hood to get it to close....I dont think thats it tho with fiber images since they are part of the hood where the one i had had bolts holding the latch to the hood
Old Feb 7, 2004 | 12:12 PM
Civiclx's Avatar
Default Re: (WR03Evo)
infamous fiber images 5g civic hood. I have one and there is a trick, you have to first take out the radiator bracket and make a thinner one out of sheet metal, then you move the latch higher up, and when you shut the hood, pull out on the front of the hood while pushing it down simultanouesly, i actually took the car to 100 w/o pins so i know its pretty secure
Old Feb 7, 2004 | 12:18 PM
t0ekn3e's Avatar
how would i move the latch up higher?
Old Feb 7, 2004 | 12:49 PM
PSU's Avatar
PSU
formerly DxHatchback
my only comment on my fiber images hood
Old Feb 7, 2004 | 01:42 PM
sammysnakes's Avatar
Default Re: (DxHatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">how would i move the latch up higher?</TD></TR></TABLE>
loosen the bolts and raise it up higher.
when i first got my FI hood it wouldn't close. i raised the latch and used a dremel tool to cut a whole in the underskeleton just big enough for the radiatort cap. now it fits like factory.
Old Feb 7, 2004 | 01:44 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: fiber images hood wont close... (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">When swapping from a JDMShit.com hood back to an OEM hood we did'nt have the hood far enough forward and part of the latch was hitting the underside of the hood, not allowing it to close. I suggest taking out your grille (if it's on an EK) and watching to see what's keeping it from closing. </TD></TR></TABLE>
darn that richard, that hood looked sooo sweet!!! oh well, to each his own i guess..
Old Feb 7, 2004 | 06:25 PM
mrnicolas's Avatar
welcome to the joy of owning a fiber images hood! Mine did the same thing. I had to dremel out my bold holes on my hood latch so I could move the latch up. It would not shut, but I had some nasty gaps on the thing. This is why I sold my hood. I had a bad experience with that company.
Old Feb 21, 2004 | 01:41 PM
275Performance's Avatar
Default Re: (mrnicolas)
I can post some SUPER NASTY pics of our del sol's CF hood. Its haggard as **** looking. I'll get them up tonight I hope. The hoods coming off anyway.
FB
Old Feb 21, 2004 | 02:58 PM
cccya's Avatar
Default Re: (275Performance)
try taking off the rad. support. i made my own out of thin alun. and that fix it...
Old Feb 22, 2004 | 05:54 AM
Default Re: (cccya)
I'll try and get some pics today, it was dark when I got home. Our hood wasn't even wide enough to cover the space that the stock on did, there is like a full inch gap on the pass. side and like a 1/2in gap on the driver's side. And the hood sticks up about 1 in higher than the fender going down the entire passenger side too. You can easily see the entire engine bay when you look through.
skaraider
16
Aug 6, 2012 09:51 AM
integraty95
Apr 21, 2009 01:18 AM
hondacrx2
Oct 12, 2007 10:16 AM
lblingldawg
10
Apr 21, 2006 07:27 AM
ShadyBAB
Nov 1, 2005 06:28 PM
