little update of my racecar..
Old Feb 6, 2004 | 03:41 PM
dmotoguy's Avatar
Default little update of my racecar..
Modified by dmotoguy at 1:23 AM 2/7/2004
Old Feb 6, 2004 | 03:45 PM
DxTrix's Avatar
Default Re: little update of my racecar.. (dmotoguy)
Looking good.
Old Feb 6, 2004 | 03:47 PM
Boostin'RPS13's Avatar
Default Re: little update of my racecar.. (DxTrix)
good start.
What kind of powerplant do you plan to use?
Old Feb 6, 2004 | 04:01 PM
dmotoguy's Avatar
Default Re: little update of my racecar.. (Boostin'RPS13)
k20a2
Old Feb 6, 2004 | 04:02 PM
lovitalracer's Avatar
You might want to check NHRA rule book on your back bars ..
I beleive it stated that they need to be angled at a 30 degrees downward ..
Old Feb 6, 2004 | 04:56 PM
This One's Avatar
Default Re: little update of my racecar.. (lovitalracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lovitalracer &raquo;</TD></TR><TR><TD CLASS="quote">You might want to check NHRA rule book on your back bars ..
I beleive it stated that they need to be angled at a 30 degrees downward ..</TD></TR></TABLE>
I also think that if you have to bend the down bars you have step up in tubing size/thickness i believe
Old Feb 6, 2004 | 04:59 PM
dmotoguy's Avatar
Default Re: little update of my racecar.. (tHIS oNE)
im pretty sure the guy who did it has it all under control.. but i'll check with him
Old Feb 6, 2004 | 05:39 PM
tony1's Avatar
Looks good, but i'd probably put some more support on the steering column. The triangle piece is the right idea, but it should be closer to the steering wheel. Doesn't the column flex quite a bit? If you run bars from the dash bar to the column, closer to the steering wheel, it'll be ALOT stiffer. This pic doesn't show it best, but you can get an idea. This column doesn't flex at all. The column in Rado's old car did quite a bit and the tubes were coming about halfway up the column.
Old Feb 6, 2004 | 07:03 PM
DaveF's Avatar
Default Re: little update of my racecar.. (tony1)
also....
---i believe the seat cannot be adjustable
---must have a brace from the shoulder bar to the back side of the seat(or the seat tight up against the shoulder bar)
-- your window net connection on the bottom cannot be detachable like it is.
Old Feb 6, 2004 | 08:17 PM
dmotoguy's Avatar
Default Re: little update of my racecar.. (2.2Lcivic)
thanks for all of your guys' help. looks like its time to change some things!
Old Feb 7, 2004 | 04:24 AM
fulldragcrx's Avatar
Great start, reminds me of mine in the early stages. keep going ,season starts sooner than you think.
Old Feb 7, 2004 | 04:39 AM
socaliracer's Avatar
Looking very good... So what total weight are you expecting? Just to be on the safe side I would check out the 2004 NHRA rule book just to see if everything is A-OK! Good Luck!!!
Old Feb 7, 2004 | 05:59 AM
AussieK24's Avatar
Default Re: little update of my racecar.. (socaliracer)
Looking good, mate
Old Feb 7, 2004 | 06:34 AM
FULLTHROTTLE's Avatar
It looks as though you only have a roll bar legal to 11.00?
If so you dont need to have the rear bars at the 30 degree angle. That is only for a full cage.
The seat thing Im not sure on the book really is'nt clear. What class are you going to be in?
Old Feb 7, 2004 | 07:53 AM
Jokerluv's Avatar
loods decent
Old Feb 7, 2004 | 10:34 AM
dmotoguy's Avatar
Default Re: (Jokerluv)
all motor class, nhra.. i want it to be legal to run 9's.. i took the guy the rulebook when i took him the car, wonder if he even read it... i'll see what all needs changed tonight.
Old Feb 8, 2004 | 08:50 AM
JUNcr-x's Avatar
Default Re: (dmotoguy)
good stuff
Old Feb 8, 2004 | 10:21 AM
Relick!'s Avatar
Default Re: (JUNcr-x)
very nice good start..so what is your game plan for the ride anyways? what type of suspensoin and motor setup are you planning?
Old Feb 8, 2004 | 03:27 PM
Timmay's Avatar
Default Re: (Relick!)
if you just going to run at firebird i wouldnt worry to much about the roll cage. they dont check stuff to the "T" like some other tracks
TooCoolToSpool
Oct 23, 2007 08:24 PM
turbotime
May 13, 2007 07:15 PM
I B Z
Jul 6, 2005 09:11 PM
Nextelbuddy
Jan 9, 2004 04:52 PM
Dave01
Dec 6, 2003 05:25 PM
