question about civic header and exhaust!
Does any body know if there is any header or exhaust system that will fit my 99 civic lx 4d? 'Cos I got an exhaust that claims to fit 92~00 civic but it didn't fit mine. Any idea? Thanks!!
I don't think they made the LX in a 2door, so you need an exhaust for a 4 door. The hatch and 2door are interchangeable (all of the B pipes are the same) so keep your B pipe and swap it for a 2door b pipe.
EDIT: That should cover the exhaust. As far as a header you need a 92-00 D series header, but you will eliminate the in exhaust manifold cat and you will have to hack up your exhaust to put one downstream.
that would be wrong man...96-00 civic exhausts r interchangeable with 2/4 doors...hatchback exhausts r shorter...(i have a 98 4 door with a 2 door invidia exhaust on it from a 99 ex)...im not sure if u have the catalytic converter problem...92-95 exhausts may be a lil diff...what is the problem you are having with fitment...does it not reach the header...or cat...or noes it rub in places?
laidave999
Feb 6, 2004 01:24 PM
