smog help please!
Old Feb 6, 2004 | 12:45 PM
90civic_tio's Avatar
Default smog help please!
i just dropped a d16y8 in my 90 lx 4 door about a month ago and i went to get it smogged and it failed to pass, sorry but i dont have a scanner to post pic of sheet but ill try to type where it failed, please help since my temp. moving permit is about to expire and i have no idea of what could be wrong...
NO (PPM)
max gp meas
835 2054 3181 @ 15 mph = gross polluter
774 1854 2651 @ 25 mph = gross polluter
it also failed at timing it was at 12btdc instead of at 18
the shop said it was a heating related problem ( but the funny thing is that just 2 weeks ago i just dorve it up the south lake tahoe ca from s.f. ca with NO problems, it was a little more than a 4 hour drive just to get there
those were the only 2 things it failed at
i would greatly appreciate any kind of advice
thanks for ure advice and for your time
Old Feb 6, 2004 | 01:14 PM
Default Re: smog help please! (90civic_tio)
bump ( any info out there? )
Old Feb 6, 2004 | 02:22 PM
anyone?
Old Feb 7, 2004 | 11:20 PM
bump
Old Feb 7, 2004 | 11:42 PM
Proper's Avatar
Try correcting your timing. If it is over advanced it will cause emissions problems
Old Feb 7, 2004 | 11:57 PM
Default Re: smog help please! (Proper)
the shop told me that even if i fixed the timing it wouldnt be enuf to fix the NOx reading...
Old Feb 8, 2004 | 12:22 AM
bossman032's Avatar
haha.
SMOG is crazy in cali a Lot off things can cause nox. Ur cat might me dead ur timing might have to do something with it.. carbon build up vacuum leak do u have a EGR system..?
The old Honda motors produce a lot of NOX most off them don't pass especially the jdm motor produce hell nox
Good luck. You can try a few solutions like the alchol solution please search I think it helps for NOX
but ur HC might rocket up
Old Feb 8, 2004 | 12:39 AM
Default Re: smog help please! (bossman032)
hmmmm... so that might be the problem since the engine i just droped in it is a jdm but it has about 40.000 miles...
Old Feb 8, 2004 | 10:23 AM
bossman032's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civic_tio &raquo;</TD></TR><TR><TD CLASS="quote">hmmmm... so that might be the problem since the engine i just droped in it is a jdm but it has about 40.000 miles...</TD></TR></TABLE>
the mileage don't matter. the jdm engines are never desigined to pass any kind of emissions. I seen some jdm motors pass most off them have a hard time with nox
Old Feb 9, 2004 | 04:44 PM
so what should i do?... the shop also tested my car as a 1.5 instead of as a 1.6.... would this make any difference in the results?
Old Feb 9, 2004 | 08:30 PM
bossman032's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civic_tio &raquo;</TD></TR><TR><TD CLASS="quote">so what should i do?... the shop also tested my car as a 1.5 instead of as a 1.6.... would this make any difference in the results?</TD></TR></TABLE>
well the 1.5 can pass with a higher score. if its newer it has to produce lower scores. if its older it can pollute more.
_ijayyy
Jul 4, 2012 01:49 AM
langjairicer
May 28, 2010 01:13 AM
Green Deli
Sep 16, 2009 06:17 PM
DC4_MADMAN
May 31, 2005 11:12 PM
voltronR34
11
Nov 15, 2002 10:16 PM
