Phantom Grip LSD
Old Feb 6, 2004 | 05:04 AM
BlendedEJ8's Avatar
Default Phantom Grip LSD
anyone heard any good things or bad things about phantom grip. i know allen told me about them (from h-heaven btw) and thats about it though. imma swap a gsr into my '99 civic ex coupe and want lsd so yea. what are some other good slips??
Old Feb 6, 2004 | 05:28 AM
shermanyang's Avatar
Default Re: Phantom Grip LSD (Taffeta_EXcpe)
if you can, get a quaife....lifetime warranty can't beat that.
Old Feb 6, 2004 | 05:37 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: Phantom Grip LSD (shermanyang)
i've read some bad stuff on the Phantom Grip LSD.
Do a search... you'll find some interesting stuff..
kENNy
Old Feb 6, 2004 | 05:38 AM
kKdARIAN's Avatar
Vice President/CEO
https://honda-tech.com/zerothread?id=727765
here is a GREAT thread about what your looking for...
Old Feb 6, 2004 | 06:04 AM
scratchy's Avatar
well he phantom grip is the only lsd setup for that cheap but its not a full lsd when you launch soon as it detects wheel spin then it locks the wheels as where a normal lsd is lock all of the time but the phantom is awesome for the price call them and talk to a rep if you have any questions very informative
Old Feb 6, 2004 | 06:05 AM
degooser's Avatar
you would be better off welding your diff then wasting your money on this thing....
Old Feb 6, 2004 | 07:41 AM
Kidnkorner's Avatar
i can't speak for anyone but my self. its not an LSD. its a differential locker. it performs in the same manner as a posi rear end. i had one in my turbo cavalier, as $1,000 quaife was not a an option. all i know is it pulled me thru the corners like no bodies business.
Old Feb 6, 2004 | 07:46 AM
c1civic's Avatar
yuck dont get the phantom grip. i got the quafie.. but for a little more than the phantom grip, u can jsut get a stock type r lsd, that should do jsut fine
Old Feb 6, 2004 | 07:56 AM
B16Drag's Avatar
Has anyone of you ever launched and felt like your car was going to smash into the side wall? Well thats what phantom does.... NOTHING!
I've used it and launching off the line with a 100 shot of nitrous, the phantom will not "grip!"
todaspecsi's Avatar
my friend swapped a jdm b16 with an si tranny equipped with phantom grip. It helps off the line because it does lock the wheels but real LSD can have an inbetween stage between locked and unlocked. compared to the phantom grip it is either locked or not. It is true though that phantom grip will pull you through corners. True LSD is torque sensitive and can I believe thats how its more accurate and can have the inbetween stages of locked or not, (not completely positive bout thats how it detects it ) but .....it all boils down to you get what you paid for. Phantom grip isnt bad if all you are gonna do is drag and drive in a straight line forever. I hate drivin my friends civic with Phantom grip because i dip through corners
Old Feb 6, 2004 | 08:34 AM
pdiggitydogg's Avatar
phantom grip isnt even a "real lsd"
its ****
dont waste your time or money
Old Feb 6, 2004 | 04:27 PM
BlendedEJ8's Avatar
Default Re: (pdiggitydogg)
DAMN. i didnt know they sucked that bad. i was thinkin though about jsut going w'a oem type R lsd. cant beat oem.... unless imma spend $900 on a quieffe. im not really ognan race the car either, its just a daily driver get me here get me there kinda thing. im just tired of the SOHC already. thanks peoples.
Old Feb 6, 2004 | 05:46 PM
CarbonCreations's Avatar
Default Re: (Taffeta_EXcpe)
You can get Quaife's for $799 new...
Old Feb 6, 2004 | 05:54 PM
Synergy001's Avatar
IMO...if you dont have the motor yet, i would buy it from http://www.hmotorsonline.com and just pay the extra $300 for an LSD tranny
Old Feb 6, 2004 | 05:57 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: (CarbonCreations)
phantom grip = explosion of differential above 250hp....
BOOM!!!!
it go BIZZZZOOOOMMMMMMM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
phantom grip merely acts as pressure plates between the factory diff springs and only helps to apply pressure across the spiders. as said before, the factory springs only apply pressure when under load...thus the sudden JOLT from the phantom grip.
This jolt as say....4k rpm and above (common clutch dump for burnouts) will equal exploded spiders in very short times from the stress that the differential is not DESIGNED for. HOWEVER!!! if you have a bonestock engine this will work for you just fine. On modified engines where people try to use one instead of dropping $800+ on a NORMAL LSD is where you run into the limitations of this system.
it IS aluminum after all....aluminum tends to go BOOM when stressed....
anyway, I had one on a civic. at stock it was nice. past that even at 6psi on a D16Y8 it went boom and took the tranny with it.
Old Feb 6, 2004 | 07:07 PM
Grip's Avatar
Default Re: (stackz)
phantom grip is to hondas what welding a diff is to muscle cars..cheap and stupid..do it right or dont do it at all...hell i want lsd too but im not gonna get a phantom grip..im gettinmg the jdm itr trans..lsd and final drive
Old Feb 6, 2004 | 07:20 PM
AL ASPIRATED's Avatar
Default Re: Phantom Grip LSD (scratchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchy &raquo;</TD></TR><TR><TD CLASS="quote">well he phantom grip is the only lsd setup for that cheap but its not a full lsd when you launch soon as it detects wheel spin then it locks the wheels as where a normal lsd is lock all of the time but the phantom is awesome for the price call them and talk to a rep if you have any questions very informative</TD></TR></TABLE>
Phanton Grip is actual an LSD, there is no such thing as not full.
LSD is not locked all the time, that would be called a LOCKER.
LSD is suppose to lock the wheels when it detects an axel spinning faster than the other.
Old Feb 7, 2004 | 02:25 AM
Mista Bone's Avatar
D Tranny Guru
"Phantom Slip, works so good you never know it's there!" Quote from Locash
Any other lawyers wish to fight me????
Old Feb 7, 2004 | 03:59 AM
Default Re: (Mista Bone)
the Phantom Grip is a substitute for a real LSD. kinda like Soy burgers is a substitute for Beef burgers.
anyway, if you do plan on getting the Phantom grip, just make sure you don't go power hungery later on and boost your car to 250+whp. cause if that's the case you may just want to save up now and get something worthwhile. the Phantom Grip was something i was going to get when i was all motor since it was cheap and proven to work. but when i read reviews and stories about people making over 250whp busting their trannies, i had second thoughts because i knew that i wanted one day to turbo my car and that i would exceed that 250whp mark. so just plan ahead and don't waste your money on something that would become usless later on in the road.
sh!ft
Transmission & Drivetrain
Jul 18, 2014 11:58 AM
ek4ferrio
Sep 12, 2006 08:24 PM
frostee
Oct 8, 2004 06:43 AM
dominate9
Jun 12, 2003 12:37 PM
mini-cRx
Sep 27, 2002 05:06 PM
