Jdm Itr 98 up Motors ?
Old Oct 7, 2001 | 11:43 AM
Rhetoric's Avatar
Default Jdm Itr 98 up Motors ?
Since I messed up my gsr motor Im considering on trying to get a Jdm Itr motor 98 spec. How much power do these motors make stock? I live in Cali, so how would I get it smogged and registered? If I were to pick up the 98 jdm r motor, what mods would likely get it up to 200 or more at the wheels. I believe the cr is at 11.1 so I would likely just use a spoon gasket-run jun cams. Any input or suggestions? Thanks.
Old Oct 7, 2001 | 01:45 PM
Rhetoric's Avatar
Default Re: Jdm Itr 98 up Motors ? (G S R)
Anyone?
Old Oct 7, 2001 | 02:08 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Everyone wants to get 200whp...it's a very dead horse. Do a search.
JDM ITR motors will make about 10 hp over USDM motors due to better header and higher compression. Does this sound about right to everyone?
Old Oct 7, 2001 | 03:19 PM
Benjamin Tang's Avatar
Default Re: Jdm Itr 98 up Motors ? (Ross1013)
the intake cam might be ctr spec (wish i could confirm this... sigh), and then there is the ecu fuel mapping, the jdm cat...
Old Oct 7, 2001 | 04:26 PM
Dee's Avatar
Dee
Default Re: Jdm Itr 98 up Motors ? (Benjamin Tang)
since you live in the Hitlerized state of CA getting it smogged legally is out of the question. The B18C serial number will fail the visual inspection. USDM motors say B18C1 or B18C5 but all JDM GSR and ITR motors only gave a B18C stamp.
Old Oct 7, 2001 | 04:30 PM
Stock-DC2's Avatar
New User
Default Re: Jdm Itr 98 up Motors ? (drealgsr)
To get 200whps, you will need higher CR, bigger cams, and reprogram your ECU. Of course, there are all the other small items that require to get the cams and higher CR work well together.
Old Oct 7, 2001 | 04:55 PM
Toda-R's Avatar
Banned
I heard it depends on the production date that determines if it runs a CTR or ITR intake cam.
Old Oct 7, 2001 | 06:25 PM
spoonek4's Avatar
I think the JDM 98specR motors are running 11.3:1. Make sure u get the tranny also coz u know it has 4.785final gear set. So it will make quite a bit difference on the overall performance.
Old Oct 7, 2001 | 07:00 PM
mafay2's Avatar
New User
Default Re: Jdm Itr 98 up Motors ? (spoonek4)
I don't think that is true, the 98 specR has a CR of 11.1:1. It is the Spoon balanced motor that came with the Spoon 2pcs headgasket that made it 11.3:1 CR.
But yea, make sure it come with the 98 spec 4.785 FD too, it make a world of different in acceleration.
Old Oct 7, 2001 | 07:10 PM
Stock-DC2's Avatar
New User
Default Re: Jdm Itr 98 up Motors ? (mafay2)
Yep, 11.1 CR for 98 spec JDM ITR.
I would love to try the 4.785 FD to see if it is really that big of a different, too bad the cost of opening up the tranny is too much for me right now.
gsr96cx
Mar 5, 2010 02:27 AM
importknight
Mar 15, 2008 10:59 PM
gtz
Sep 30, 2006 01:29 AM
HATCHingMN
May 1, 2005 10:09 AM
B18C5-EH2
Dec 28, 2001 10:05 AM
