RSR exhaust ticking?
Old Feb 5, 2004 | 04:07 PM
94AccordCoupe's Avatar
Default RSR exhaust ticking?
Ok, I know I'm in the wrong forum but there aren't too many knowledgeable accord people. I put on an RSR ExMag exhaust a couple weeks ago and ever since it "ticks" much louder then my stock exhaust did when it's cooling down. I can even here it ticking in the car after getting off the highway at a stop light. Is this normal for a new exhaust? Or is this common with RSR exhausts? The one thing I'm worried about is I threw away the stock spring bolts because they were rusted pretty bad and used plain bolts to fasten the exhaust together. Someone who I trust told me the spring bolts are primarily for controlling vibration and aren't to allow heat expansion like I once thought. Is my exhaust slowly destroying itslef becaue I didnt use spring bolts or is my hearing just too sensitive?
Thanks for any help
Old Feb 5, 2004 | 04:11 PM
chads's Avatar
Default Re: RSR exhaust ticking? (94AccordCoupe)
don't worry about it its your catalytic coveter, its totally normal, the hotter it gets the louder the ticks will be when you turn it off.
Old Feb 5, 2004 | 04:17 PM
Default Re: RSR exhaust ticking? (FlamencoEsi)
Sorry, I forgot to mention, I dont have a cat anymore. I guess that might cause the exhaust to get hotter though?
Old Feb 5, 2004 | 04:18 PM
deviant1's Avatar
i have an old school rsr exhaust and mine ticks as well when the car is turned off. i can also hear mine every now and then at a stop light with the windows down. im interested to know if its anything bad
Old Feb 5, 2004 | 05:15 PM
Default Re: RSR exhaust ticking? (deviant1)
bump
Old Feb 5, 2004 | 05:19 PM
Johnny76's Avatar
I have the exact same problem with my RSR Ex-Mag for my EH which I put on about a month ago, so I'd like to know as well if this is normal or not.
Old Feb 5, 2004 | 05:30 PM
kommon_sense's Avatar
Default Re: RSR exhaust ticking? (Johnny76)
mine does it as well. I'm wondering if the ceramic coating causes it. also check to make sure that all of your exhaust bolts are still tight. Mind was ticking pretty loud and I found that I had lost a few bolts A little loctite took care of that.
Old Feb 5, 2004 | 06:45 PM
sombasol's Avatar
My EX mag clicks too but only when the car is off, not when it's on. I've had it on for almost a year now and it still does it so I don't think it's going to stop. I'm pretty sure it comes from the muffler itself, but not sure.
Old Feb 5, 2004 | 07:26 PM
99FoxSi's Avatar
My RSR original ticks too when I tiurn off the car.
Old Feb 5, 2004 | 08:11 PM
Discosteak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94AccordCoupe &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I know I'm in the wrong forum but there aren't too many knowledgeable accord people. </TD></TR></TABLE>
for some reason i found that funny. the exhaust thing is normal every one ive seen does it
Old Feb 5, 2004 | 08:20 PM
drunknmunkypow's Avatar
mine is ticking too. the rsr is on my civic.
Old Feb 5, 2004 | 08:38 PM
Gump's Avatar
Default Re: RSR exhaust ticking? (drunknmunkypow)
Mine ticks as well, annoying as fu*k!!!
Old Feb 5, 2004 | 08:46 PM
phantom_sol's Avatar
i think its all the metal unside either the muffler or the car, ticking loudly as it cools and contracts. ???
my girlfriends moms cadillac tangs loudly from teh exhaust after she turns it off. could make sense.... heat expand, cold contract etc... no?
Old Feb 5, 2004 | 09:10 PM
Johnny76's Avatar
Is the ticking normal also while the car is running? For example, while idle at a stop light it would just start ticking.
Old Feb 6, 2004 | 09:18 AM
The ticking is most noticeable after the car has been turned off. Its the normal metal expanding/contracting ticking that you hear from a lot of vehicles. On occassion, I can hear it while at a stock or going through a drive through, but only because I listen for it. Its a normal sound, I've heard plenty of other vehicles doing it.
Old Feb 12, 2004 | 12:47 AM
BIGGIDYBOB's Avatar
Default Re: RSR exhaust ticking? (kommon_sense)
The ticking sound on my RS*R comes from the resonator. Everytime i come to a stop or i shut the car off i hear it. When i come home and go to my room i still could hear it out my window I guess its normal though since most of us owners experience it.
Old Feb 12, 2004 | 01:03 AM
Gump's Avatar
I hear mine from the resonator as well.
Old Feb 12, 2004 | 03:19 AM
Stylinhonda's Avatar
Default Re: (Gump)
I had a thread about this a few days ago. I just got my Apexi N1 on with piping from the cat back with a resonator. Im guessing you guys are right about it being the resonator. I didint have one on my last exhaust but now it ticks like a mo fo. Really anoying. I thought at 1st it was just when I turned the car off and got out. But i was at a light and i herd it and also at the drive threw. So im guessing it happends 24/7 except when the car is off and cooled.
Old Feb 12, 2004 | 11:36 AM
SpoonEK2's Avatar
Default Re: (Stylinhonda)
it's normal for RS*R
jkalex05
Aug 8, 2009 02:09 PM
eggsi619
Jan 13, 2009 10:49 AM
Jordans95si
Aug 6, 2005 07:58 AM
hype r 555
Aug 31, 2004 01:30 PM
civic-cpe
Sep 15, 2002 07:59 AM
