damnit..tranny grinds in 3rd on hard shifts
Old Feb 5, 2004 | 03:51 PM
Grip's Avatar
Default damnit..tranny grinds in 3rd on hard shifts
this sucks man..all this winter my car has been givin me ****..first i need to replace both axels..then i have to take emissions..now on the way home from work today i notice my car is starting to grind going from second into 3rd..it dosent do it all the time only when im at about 8500 rpm or above and shiftin hard..if i shift at 8500+ and shift slow its fine but if im slammin gears it grinds slightly..is there any way to prevent this from getting worse or maybe treat it?..or do i have to replace some **** inside my tranny?..i really dont wanna rebuild it
Old Feb 5, 2004 | 03:53 PM
xerox445's Avatar
Default Re: damnit..tranny grinds in 3rd on hard shifts (Grip Driver)
what kind of engine do you have that your consistantly reving it up to 8500+, driving to work no less....christ, you need to calm the hell down in your car
Old Feb 5, 2004 | 03:55 PM
Happyman's Avatar
Default Re: damnit..tranny grinds in 3rd on hard shifts (xerox445)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of engine do you have that your consistantly reving it up to 8500+, driving to work no less....christ, you need to calm the hell down in your car</TD></TR></TABLE>
Was thinking the same thing.
Old Feb 5, 2004 | 03:57 PM
pdiggitydogg's Avatar
well aside from the fact that yes, you drive like a maniac
Try double-clutching (I hope you know how to do it right) and maybe gm synchromesh (the friction modified stuff) until you can afford a rebuild (If its even that bad)
RedHackBatch's Avatar
change your gear oil or another thing you can do is not take it up that high
Old Feb 5, 2004 | 03:59 PM
Discosteak's Avatar
replace your tranny fluid with gm syncromesh friction modified it should get rid of the grind. oh and slow teh fuxor down
edit: beat me to it twice
The Internet Tough Guy's Avatar
Default Re: (pdiggitydogg)
check rear and front lower motor mounts: they may be worn, causing your engine and transmission to unwantedly shake around at high rpm. replace them, fill with window weld, or add es poly inserts and it should stop.
Grip's Avatar
Default Re: damnit..tranny grinds in 3rd on hard shifts (Happyman)
im not constantly reving to 8500+rpm but everyonce in a while some old lady needs to have a heart attack because she drives so damn slow
b16 motor and trans
once it happened today for the first time i had to do it a few more times to see when and how it actually happens and i found out it happens at high rev shifts into third only
Old Feb 5, 2004 | 04:02 PM
nY's FiNeSt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip Driver &raquo;</TD></TR><TR><TD CLASS="quote">im not constantly reving to 8500+rpm but everyonce in a while some old lady needs to have a heart attack because she drives so damn slow </TD></TR></TABLE>
uhh ok that's smart
anyways try flushing the tranny fluid and putting either some honda mtf or gm synchromesh like suggested before
Grip's Avatar
hahah i dont always drive like a maniac ...usually i drive like a garandpa...but today i had to beat on my car to see what and why this 3rd gear grind happens...im gonna be replacing my axels this weekend so when i do that ill try that gm synchromesh friction modified fluid..where can i buy it&gt; i usually use oem honda manual trans fluid
Old Feb 5, 2004 | 04:03 PM
xerox445's Avatar
yo do realise everytime you shift that high, your syncros have to work over time to match the speed of the gears...they were probly worn down bad already with the way your drive, and your last almighty 8500+rpm pull screwd them up real good...
What do you have done to your motor to be able/ have reason to hold a gear that high? You know the power on a stock motor starts to taper off bad way before that right.....
Btw, 500th post
Old Feb 5, 2004 | 04:07 PM
Grip's Avatar
Default Re: (xerox445)
is gm synchromesh friction modified a general motors fluid or is it an aftermarket fluid?..where can i buy it?
and for the last time..im not always shifting at 8500 rpm...i dont drive around racing everyone and everything i see..i was doing some spirited driving and i noticed it grinds into 3rd gear..so i tried it a few more times to see when the grind occurs
Old Feb 5, 2004 | 04:28 PM
skip.two's Avatar
Default Re: (Grip Driver)
hm, this kinda helps me too. my tranny grinds going into 3rd, but not like this guy 8500rpm is crazy. well yea, i was told that i would need new synchros.
Old Feb 5, 2004 | 04:32 PM
Ricey McRicerton's Avatar
You can get it from your local GM dealer. And also check your motor mounts. That could cause this as well.
Old Feb 5, 2004 | 04:52 PM
Grip's Avatar
Default Re: (Ricey McRicerton)
its not the motor mounts..turst me
Old Feb 5, 2004 | 04:53 PM
Matty.'s Avatar
Default Re: damnit..tranny grinds in 3rd on hard shifts (BADEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADEG6 &raquo;</TD></TR><TR><TD CLASS="quote">replace your tranny fluid with gm syncromesh friction modified it should get rid of the grind. oh and slow teh fuxor down
edit: beat me to it twice</TD></TR></TABLE>
what he said
Old Feb 5, 2004 | 08:55 PM
http://www.gmpartsdirect.com/results.cfm
part # 12377916
you dont need all that you get...sell it off or save for MILES down the road
jr408
Feb 27, 2008 11:50 AM
mcc361
Sep 4, 2007 12:38 AM
Blackline47
Honda Civic (2006 - 2015)
16
May 27, 2007 10:48 PM
buzlink
Nov 19, 2005 05:03 PM
DrewQ1
Feb 26, 2004 04:12 AM
