d16z6 build up!! need a bit of advice?
will be building up my d16z6 soon! its getting all new bearings, and stem seals, all gaskets etc.
1, should i coat things like main bearings and con rod bearings in some sort of oil before i install them?
2, Is there any procedure when replacing valve stem seals! or should i just rip em out???
3, Is there any other alternatives to using honda bond???
any suggestions for the rest of build up??? Thanks in advance for any help
1. refer to your manual, it will tell you. shouldnt be doing a rebuild without it anyway.
2. refer to your manual, it will tell you. shouldnt be doing a rebuild without it anyway.
3. https://honda-tech.com/zerothread?id=717838 (got that using the search)
thanks for the input! plan on using some eagle rods think i have to notch the block for them to fit and some sort of aftermarket pistons have'nt decided on which brand im going with?
jgomega16
11
Oct 15, 2004 12:19 PM
