D16y9 Specs??????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARAXIS »</TD></TR><TR><TD CLASS="quote">here in my country all civic come to y9!!!! is likek a y7 whit y8 Im </TD></TR></TABLE>
Couldn't you get away with just putting the Y8/Y9 manifold on then?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtmamg »</TD></TR><TR><TD CLASS="quote">
Couldn't you get away with just putting the Y8/Y9 manifold on then?</TD></TR></TABLE>
my y7 head dont wotk fine trouble whit turbo before
my y7 head dont wotk fine trouble whit turbo before</TD></TR></TABLE>
It should be a straight up swap then. I don't see how you'd have any trouble with it.
He is saying the engine that he is getting the head has 127 horses, then you are looking at the y8 (EX) head. It is a direct swap and their have been several threads on doing a mini-me conversion. Does anyone have the link? I have to run to class.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARAXIS »</TD></TR><TR><TD CLASS="quote">1- i need head my head is **** off.......and i see suposed that engine have 127hp my have 106 </TD></TR></TABLE>
you need some head?
you need some head?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">
you need some head?
Don't we all?
Back on topic, if D16Y9 = D16Y7 head + D16Y8 Manifold, then D16Y7 block + D16Y9 Head = no problem.
you need some head?
</TD></TR></TABLE>Don't we all?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goulasos »</TD></TR><TR><TD CLASS="quote">He is saying the engine that he is getting the head has 127 horses, then you are looking at the y8 (EX) head. It is a direct swap and their have been several threads on doing a mini-me conversion. Does anyone have the link? I have to run to class.</TD></TR></TABLE>
ex are vtec in my country is the same ex whit out vtec cam!!!!!.......................................... ...........
you need some head? </TD></TR></TABLE>
and yes i need new head!!!!
here is dificulty to find vtec heads!!!
hable espanol, y tratare de ayudarlo
la prueba para obtener el motor de un VTi civico
usted puede poner la cabeza de motor del civico ex (Y8) en su bloque (Y7) cÃÂÂ*vico de motor este es una variacion del intercambio de mini-me
adoro el VTi civico. deseo que ellos lo vendieran aqui. solo estaba disponible en el cupe
_____________
im a jackass don't listen to me
For the finest in JDM engines and better pricing than hmotorsonline.com Click Here
[B][I] Can you hear me now? Good!!
2000 EK HB
Modified by Huggy Bear at 4:17 PM 2/5/2004
_____________
2000 EK HB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Huggy Bear »</TD></TR><TR><TD CLASS="quote">hable espanol, y tratare de ayudarlo
usted puede poner la cabeza de motor del civico ex (Y8) en su bloque (Y7) cívico de motor este es una variacion del intercambio de mini-me
ummmmmmm ok sure
</TD></TR></TABLE>ummmmmmm ok sure
d_EG COUPE
May 26, 2008 12:07 AM
