Window Lining
My outside window lining is inside the window. I tried to pull it out and on top of the window but when the window rolls down it just pops back to its original position. Is there some obvious solution I do not see? Where can I buy some OEM window lining?
-Will try to get some pictures up to help show what i mean.
The weather strip at the bottom of the window on the outside? Mine are dry rotted to **** (gone) from the sun in Arizona (where my car came from). I need new ones too. You should probably check out the stealership. That's probably the only place you'll be able to get them.
