Stress Fractures on Rotors!!!
Old Oct 7, 2001 | 12:41 AM
N1Spec's Avatar
New User
Default Stress Fractures on Rotors!!!
should i swap out my rotors?? or will it be ok for 1 more trackday?
Old Oct 7, 2001 | 04:20 AM
SnyperSiR's Avatar
Default Re: Stress Fractures on Rotors!!! (N1 Spec)
I'm surprised your rotors aren't warped already due to those fractures. Swap them out; better safe than sorry, right?
Old Oct 7, 2001 | 05:19 AM
Honda318dx's Avatar
Got pics??? I always have stress marks in mine.. You are the one with the over kill brakes right?
Old Oct 7, 2001 | 09:59 AM
Andrew Sites's Avatar
Don't worry, mine have had the same for the last 4 track days. Glen K. (Gansan on this board) ran his like this for a years worth of track days. Make sure to have a set of spare pads and rotors at the track with you just in case.
Old Oct 7, 2001 | 10:10 AM
arren123's Avatar
Default Re: Stress Fractures on Rotors!!! (Andrew)
One of my rotors is wearing down unevenly, I can see a 1 mm concentric line going around. If you take your fingernail you can really feel the edge of it. Should I just screw it and let it keep wearing down that way? Or get the rotors cut? If I do get the rotors cut, will I have to change the brake pad? Hmm.. Maybe warantee will cover this one???
Old Oct 7, 2001 | 10:22 AM
Default Re: Stress Fractures on Rotors!!! (arren123)
I would never have the rotors turned (cut), unless they are warped and you cannot afford to replace them with a new set.
As for the uneven wear, its normal. When it begins to affect pad life and or the pads just wear down, I would replace both the pads and rotors.
Old Oct 7, 2001 | 12:34 PM
Gansan's Avatar
Yes. Don't worry too much about small fine fractures in the surface of the disk. They will slowly grow over time until one of the cracks goes all the way through the disc, but that takes a very long time, and the failure is not usually catastrophic. I don't recommend machining the rotors since it will just make the cracks grow faster. You are grinding off the cracked part of the material, but you are not relieving any of the internal stresses that are causing the crack in the first place.
So in summary, a few fine cracks are ok--just keep an eye on them and inspect the rotor after every run. When they get too numerous, then replace the rotor. Don't machine it. And always carry spares.
Old Oct 7, 2001 | 03:53 PM
N1Spec's Avatar
New User
Default Re: Stress Fractures on Rotors!!! (Gansan)
thanks for the info.......
some guy told me that the rotors may disintegrate or explode??? is that BS or what?
so basically stress fractures on rotors are unavoidable if you always track your car??
Old Oct 7, 2001 | 04:51 PM
Willard's Avatar
Very much a load of BS.
Unavoidable... yes.
Unless you have massive amounts of air supplied to the rotors... they will develop stress cracks. Just keep extras on hand.
Happy lapping days.
Willis
-who will be lapping VIR this Fri/Sat/Sun (and will be bringing extra r0t0rs with him)
Old Oct 7, 2001 | 04:57 PM
evil vapor's Avatar
the rotors wont explode or disintegrate. Some people like to scare other people just for the fun of it or scare them into buying a part they really don't need. If you track your car, you'll have to deal with keeping a closer eye on your car. If you're really hard on brakes, it's not unordinary to replace rotors and pads and bleed fluid heavily for street driving. If I were you, I'd just replace those rotors and keep them as spare ones if you drive your car daily. I'm just the paranoid type.
Old Oct 7, 2001 | 05:01 PM
N1Spec's Avatar
New User
Default Re: Stress Fractures on Rotors!!! (vaporsi)
haha yup i thought it was BS.....!
hmm i might give these rotors 1 last beating then i'll replace them.
thank goodness its 2 piece, instead of costing me $1000 it'll only cost me a fraction to replace the rotors only and not the hats.
Ej8_KiD
Suspension & Brakes
Mar 15, 2011 09:03 PM
schumi
31
Oct 3, 2005 12:23 PM
MikeTV
Jun 19, 2003 08:51 PM
illusion
Apr 10, 2002 09:31 AM
