02 sensor question...easy one
Old Feb 4, 2004 | 06:33 PM
SiRkid's Avatar
Default 02 sensor question...easy one
on the 0b2 cars.
the 2 sensors are the same are they not.
just ones before the cat and ones in the cat.
on hondaautomotive parts the part numbers for them differs by 2 (same price though) but Ive always thought of them as being the same thing.
or am I wrong?
thanks
sorry for the brain fart..lol
Modified by SiRkid at 3:46 AM 2/5/2004
Old Feb 4, 2004 | 08:38 PM
hondatim's Avatar
Default Re: 02 sensor question...easy one (SiRkid)
I'm pretty sure they are different due to calibration. but not 100% on this
Old Feb 4, 2004 | 08:42 PM
Team 4R's Avatar
i don't think they're the same at all....... the first one reads your a/f ratio (well, you know what i mean...) and the second just makes sure your cat has a consistent output......... i think.
Old Feb 4, 2004 | 11:00 PM
HondaTechPro's Avatar
Well most of the replys are sort of right. The sensors are the same themselevs. The difference is in the shape of the electrical connector. The front O2 will only plug in to the front O2 connector and the rear will only plug in to the rear.
Old Feb 5, 2004 | 07:42 AM
Boofster's Avatar
Default Re: 02 sensor question...easy one (HondaTechPro)
I don't agree with the connector. I needed a longer wire to reach the down pipe so I used my secondary as my primary on my OBD2 -> OBD1. We tested it and it works. All the O2 does is send a voltage anyway.
https://honda-tech.com/zerothread?id=724246
Old Feb 6, 2004 | 04:32 AM
EE_Chris's Avatar
Default Re: 02 sensor question...easy one (Boofster)
99 Civic hatch - D16Y7
Both of my O2's share the same style connector. The difference is in the length of the wiring.
Old Feb 7, 2004 | 12:39 PM
SiRkid's Avatar
Default Re: 02 sensor question...easy one (EE_Chris)
ok i did some more poking around.
THE SENSORS and connectors are the same.
the difference is wire length and the secondary has a rubber grommet on it to close the hole in the body where the wire goes into!
Accurate GS-R
Oct 19, 2004 08:20 AM
rhettster
Jul 24, 2004 09:07 PM
2lobes1engine
11
May 11, 2004 03:14 PM
piotrush
Feb 9, 2004 09:28 PM
iam7head
Oct 9, 2002 02:26 AM
