custome turbo's
Old Feb 4, 2004 | 05:16 PM
brando_001's Avatar
Default custome turbo's
i want to build one. I need some input though.
94 ls
magnaflow race muf./2.25 exhaust/redline chip/
short ram/B&M shorty/and a Gtech meter
any ideas or input would be helpful
Old Feb 4, 2004 | 05:21 PM
Kendall's Avatar
Here's what you're going to need:
Turbo
Manifold
Downpipe
Intercooler
Wastegate
Blow Off Valve
Oil Feed Line
Oil Return Line
Lots of Vacuum Line
Intercooler Piping
Silicone Hoses
Hose Clamps
and finally Very Good Engine Management
If you do some research and find some good deals and maybe some used parts, you can put a great kit together and have it tuned for less than $2000. Putting together a custom turbo kit is no simple matter though. Expect to be sitting in front of a computer doing research for a good many hours before you come up with a solid plan though.
Old Feb 4, 2004 | 05:24 PM
brando_001's Avatar
thanks man
Old Feb 4, 2004 | 05:25 PM
Kendall's Avatar
Remember that engine management and tuning are most the important obstacle to overcome. And don't buy your manifold off of ebay.
Old Feb 4, 2004 | 05:27 PM
brando_001's Avatar
does anyone now how accurate
the gtech meters are i got one but it's
winter here and my baby's in the garage
Old Feb 4, 2004 | 05:28 PM
brando_001's Avatar
no ebay manifold got it
Old Feb 4, 2004 | 05:29 PM
AspectIndustries's Avatar
Default Re: (Kendall)
If i was to run the above mention setup needed.
With a OBD1 chipped ECU with UBERDATA. Will I need anything else? Besides the above stated parts:
Turbo
Manifold
Downpipe
Intercooler
Wastegate
Blow Off Valve
Oil Feed Line
Oil Return Line
Lots of Vacuum Line
Intercooler Piping
Silicone Hoses
Hose Clamps
----@@@@@@@@@@@@@@@@@@@@@2
Fuel pressurizer, regulator, pump? Etc.?
Thanks.
Kendall's Avatar
Default Re: (brando_001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brando_001 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone now how accurate
winter here and my baby's in the garage</TD></TR></TABLE>
Search. This topic has been covered many times.
Old Feb 4, 2004 | 05:31 PM
Kendall's Avatar
Default Re: (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik &raquo;</TD></TR><TR><TD CLASS="quote">If i was to run the above mention setup needed.
With a OBD1 chipped ECU with UBERDATA. Will I need anything else?</TD></TR></TABLE>
I referenced Engine Management. This means fuel, ignition, and all necessary sensors. My recommendation is a Hondata set to read boost, A Walbro intake fuel pump, and some turbo DSM fuel injectors with a resistor box.
Honda Bull
Sep 28, 2009 09:36 AM
20psi17c
Feb 18, 2005 07:18 PM
OG SHG_EM1
Mar 28, 2004 09:10 PM
blueskiesfade609
Feb 29, 2004 07:19 AM
deeweezy
Jul 28, 2003 10:50 PM
