Tranny swap from DX to EX..?
I have a 94 civic DX and i have parts from a 93 civic EX i want to put the tranny from the ex in my dx but i dont know if i need to swap out anything else to make the tranny work right like.. axels, cv joints, struts, clutch **** like that , can anyone help me out who has done this project before?!
Yup, done it lots of time... Also it's really up to you but since you have the tranny off (if you have the money and you haven't done it recently) might as well swap the clutch... Again if you've already changed it then there is no need... Good Luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 »</TD></TR><TR><TD CLASS="quote">Yup, done it lots of time... Also it's really up to you but since you have the tranny off (if you have the money and you haven't done it recently) might as well swap the clutch... Again if you've already changed it then there is no need... Good Luck</TD></TR></TABLE> OK thank u , um why should i use that clutch instead of the dx, is the brake master cylnder the same on a 93 ex as a 94 dx?
No, there's no difference in the clutches or the clutch master cylinders... I just brought it up because, if you are looking at changing your clutch sometime now is probably the easiest time as you're already going to have the tranny off... That's all, no big deal... Let me know if you need anything else, it's pretty straight forward tho...
POE
16
Feb 5, 2004 08:14 PM
