bolts are stuck
Old Oct 6, 2001 | 12:19 AM
accord4banger's Avatar
New User
Default bolts are stuck
wut should i do...me n a friend tried lowerin my back...but the bolts got stuck (not the tire bolts, but the suspension area) we even used a air compressor shiet thing too, no luck, any ideas? thanks
Old Oct 6, 2001 | 06:13 AM
Gennady's Avatar
New User
Default Re: bolts are stuck (accord4banger)
spray with penertating lube/solution, or wd40. soke it, and let it sit fr 5 minutes. try hitting it gently a couple of time to get all the rust and dirt off.
Old Oct 6, 2001 | 05:21 PM
urbanlegend21's Avatar
New User
Default Re: bolts are stuck (Wont be beat)
helps if you could be more specific about which bolts they are....
Old Oct 6, 2001 | 07:01 PM
4doorH22's Avatar
Default Re: bolts are stuck (urbanlegend21)
Don't use air tools on there man.
I think you must mean "nuts," not "bolts."
Sounds like you've striped the thread on the nuts or the studs.
Last time that happened to me on a strut-top bolt, i just got a vice-grip on the nut REAL tight and just kept turning counterclockwise while pulling up real hard. Someone else might have brighter ideas for removing striped nuts.
Old Oct 6, 2001 | 07:03 PM
4doorH22's Avatar
Default Re: bolts are stuck (4doorH22)
Oh, ****. Maybe you do mean bolt. I can't imagine a suspension bolt air tools can't undo, unless you did end up either striping the threads or rounding the head.
Old Oct 6, 2001 | 07:29 PM
New User
the suspension area covers a wide region to me, if you stripped it a pair of channel locks might work
Old Oct 10, 2001 | 04:37 AM
mr2td's Avatar
New User
I'd put $10 down and say you have a seized lower strut mount. What happens is that the bolt (that holds the fork on the end of the strut, to the knuckle) seizes to the metal collar inside of the bushing. This happens on a lot of Hondas (including mine.) If you try to loosen it, it will most likely shear off inside the collar. What you will probably need to do is have that bushing pressed out and replaced (the bushing is around $11.)
Old Oct 10, 2001 | 07:12 AM
New User
Default Re: bolts are stuck (mr2td)
take a drill and set it in the bolt the back it off if done right it will work
SWC
Suspension & Brakes
May 9, 2006 08:35 PM
civiccoupe94
34
Nov 17, 2005 08:15 AM
94CoupeEJ1
19
Jun 2, 2005 06:04 PM
trellix78
Jan 26, 2005 08:20 PM
Traction
Jul 30, 2004 07:01 PM
