questions 4 the x periencd/ p.s.... got a field vtec cont.
Old Feb 2, 2004 | 11:27 PM
icon_race_eg's Avatar
Default questions 4 the x periencd/ p.s.... got a field vtec cont.
k. i got a mini swap. d16a6/y8 head. my seedo dosnt work. somtimes map sensor comes up . i have a FIELDS VTEC CONTROLLER. could there possibly be someone who knows how these things should b setup?
Old Feb 3, 2004 | 06:22 AM
USDM 4G VTEC's Avatar
Default Re: questions 4 the x periencd/ p.s.... got a field vtec cont. (mac13_34)
u have the fields setup to run too rich and its making ur MAP see out of range readings
lower ur setings to about
-16% @ 1k
-15% @ 2k
-14% @ 3k
-12% @ 4k
-10% @ 5k
-9% @ 6k
-8% @ 7k
-7% @ 8k
u will see a gas per gallon increse, and a lot more power available
beleive me, worked for me when i dyno tuned
Old Feb 12, 2004 | 05:49 PM
Default Re: questions 4 the x periencd/ p.s.... got a field vtec cont. (USDM 4G VTEC)
these seem way too lean. what setup up did u have when u ran it this lean? ive been runnin all kinds? so but not even that low ill try it. this is kinda what i have now...
3@1k
6@2k
10@3k
14@4k
vtec@4100
18@5k
20@6k
23@7k
30@k
most power ive gotten out of it is 141 peak with my gt2 g meter,
in michigan. now im in az @ 5500 ft. thats like 4psi loss compared to phoenix. i figured i should run a little bit leaner, but im stuck with 91 octane and it has gay *** oxidizers, like ether and ethenol, which make it leaner. hopefully its not confusing but i really need good figures. let me ur ideas. appriciate it later.
Old Feb 24, 2004 | 10:17 AM
Xsi's Avatar
Xsi
Check your wiring and the plug into the back of the unit, MAP sensor codes are common with the SFC
mortificationrock
Jul 18, 2007 10:22 PM
G2TegGuy
Jan 19, 2006 08:24 AM
Mario.
Apr 29, 2005 08:37 AM
ImportechPerformance
Jan 24, 2005 09:57 PM
chirp2hrd
17
Sep 17, 2002 10:21 AM
