MPFI HELP!!!
Old Feb 2, 2004 | 06:15 PM
Civmochris's Avatar
Default MPFI HELP!!!
Me and My friend Vong did the MPFI swap on my std. we did all of the wires right we went through and did it twice to make sure it was right but still will not start. i needed to ask to questions.
1 can you use a 92-95 dis. if you repin it and
2 can you use 1st gen sir b16 injectors. that is the only injectors we could fined in his garage. please help i miss my hatch.
also we are throwing code 10 and code 20
we changed the iat sensor and still getting code 10
thanks
Cimochris
Old Feb 2, 2004 | 06:19 PM
Redline130's Avatar
Default Re: MPFI HELP!!! (Civmochris)
First off, no you cannot use a 92-95 distributor unless you are using a OBD1 ECU as well. The B16 injectors will be fine though. As for your IAT sensor, make sure that you have the right connector plugged into it. Chances are you might have plugged in the IACV connector instead, switch the two and see if that helps. Also, what ECU are you using?
HondacivDX
Jan 22, 2011 09:12 AM
H22Ej1
Jan 23, 2009 10:35 AM
monstercrx
Nov 30, 2004 08:02 AM
integlikewhoa
Mar 8, 2004 07:12 PM
