y7/y8 mini me swap questions....
Old Feb 2, 2004 | 03:39 PM
88hondahatch's Avatar
Default y7/y8 mini me swap questions....
so me and my buddy tore the head off his d16y7 yesterday and are doing a mini me on it with a y8 head he picked up for $25 (including manifold, edu, head and 2 distributers.... good deal ) and today he went to port the head with a dremal and started to look for differences in sensors and such. 2 questions arose.
1) will we need a knock sensor?
2) the IAC valve on the y7 manifold is 3 wire and is oval shapped while the one on the y8 head is 2 wire and circular much like the map sensor or TPS sernsor, how do we get around this if we plan on using the y8 maninfold with the y7 harness.
thanks for any replys and sorry if this has been posted before but did a search and nothing relavant came up
Old Feb 2, 2004 | 03:45 PM
BauleyCivic's Avatar
Risky Business
Default Re: y7/y8 mini me swap questions.... (88hondahatch)
https://honda-tech.com/zerothread?id=735196
Old Feb 2, 2004 | 04:05 PM
Risky Business
Default Re: (88hondahatch)
oh sorry try this one too: https://honda-tech.com/zerothread?id=615978
and this https://honda-tech.com/zerothread?id=622675
Old Feb 2, 2004 | 04:23 PM
thanks these are a big help
Old Feb 3, 2004 | 02:38 PM
another quick question....
anyone know what timing belt and water pump to use? should we order the y8 or y7 water pump or are they the same? and what size timing belt?
Old Feb 3, 2004 | 07:07 PM
Risky Business
y8 T belt (although y7 and y8 are the same both 104 teeth) and y7 water pump
Old Feb 3, 2004 | 07:26 PM
dsadas89das78934's Avatar
Y7 timing belt = Y8 timing belt
pnwjdm
27
Feb 17, 2014 01:31 PM
SOHC_civic_si
May 4, 2008 08:50 PM
chue_li
10
Mar 14, 2005 02:45 PM
