cure for hondata hesitation?
Old Feb 2, 2004 | 11:09 AM
integracivic94's Avatar
Default cure for hondata hesitation?
anyone know a cure for hondata hesitation??
Old Feb 2, 2004 | 12:29 PM
mike1114's Avatar
Default Re: cure for hondata hesitation? (integracivic94)
haven't tried these but from research this is what I found.
Richen up columns 4-5 on fuel maps.
OR
use P28 basemap and save P72 fully tuned maps over top of the P28 baasemap, seems to smooth out some.
Or maybe both??????
Old Feb 2, 2004 | 01:30 PM
sweet's Avatar
Default Re: cure for hondata hesitation? (mike1114)
i'm not sure which hesitation you are referring to, since i have heard of both the 3K rpm and part throttle hesitations. i personally have the part throttle hesitation problem. only happens at a particular throttle position, whether it be 2-3K or 6-8K rpm. but some have mentioned that it only seems to happen around 3K rpm at any given throttle position. i am using the base S100 Hondata system w/P28 ECU currently, and only have the part throttle position hesitation which happens to be the throttle angle that i normally cruise at on the highway in 5th gear. that's a pain in the a** for sure.
i hope to get to the dyno in the future and do some fine tuning, maybe to eliminate the hesitation problem and find more power.
Old Feb 2, 2004 | 01:38 PM
SKDRCR's Avatar
Default Re: cure for hondata hesitation? (sweet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sweet &raquo;</TD></TR><TR><TD CLASS="quote">
i hope to get to the dyno in the future and do some fine tuning, maybe to eliminate the hesitation problem and find more power. </TD></TR></TABLE>
wurd.....take it to a good hondata tuner
Old Feb 2, 2004 | 01:50 PM
sweet's Avatar
Default Re: cure for hondata hesitation? (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">wurd.....take it to a good hondata tuner</TD></TR></TABLE>
yes, i have one locally who can do that for me. we did some street tuning and realized the problem right away, but couldn't fully tune it out. so that's why i am hoping to make it to the dyno and do some better tuning with the Hondata, along with some cam gear changes too.
myefhasaname
Engine Management and Tuning
Oct 28, 2013 02:07 PM
turbotime
Oct 24, 2005 09:11 AM
Aeka GSR
Apr 28, 2004 09:26 AM
maxxd97
Jan 26, 2004 11:07 AM
92HB_HB
Feb 1, 2003 09:22 PM
