b16 crank in b18 block
its been done buy a few h-t members but it is a pain you need custom lengh rods and the pins on the pistons need to be upsize by like 6
best thing for a b16a if you want more cc would be to go with a 1.7 gsr crank and gsr rods with your b16 pistons perfect fit and will raise up your displacement and compression ratio.
.best thing for a b16a if you want more cc would be to go with a 1.7 gsr crank and gsr rods with your b16 pistons perfect fit and will raise up your displacement and compression ratio.
