aftermarket fuel pump & fuel pressure regulator help
Old Feb 2, 2004 | 07:52 AM
hksturbolude's Avatar
Default aftermarket fuel pump & fuel pressure regulator help
hey guys, my 4th gen is in the shop right now im getting a jdm h22a dropped in...my question is, i had a walbro 255 aftermarket fuel pump installed with my turbo kit, but im gonna be running the stock h22a fuel rail...is there going to be a problem running the aftermarket fuel pump with a stock fpr?....if so, should i spend my money just getting a brand new stock fuel pump or getting another aftermarket fpr(the one on the car now was sold with the turbo kit) thanks a lot!
Old Feb 2, 2004 | 08:07 AM
lildrgn2.0's Avatar
New User
Default Re: aftermarket fuel pump & fuel pressure regulator help (hksturbolude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hksturbolude &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, my 4th gen is in the shop right now im getting a jdm h22a dropped in...my question is, i had a walbro 255 aftermarket fuel pump installed with my turbo kit, but im gonna be running the stock h22a fuel rail...is there going to be a problem running the aftermarket fuel pump with a stock fpr?....if so, should i spend my money just getting a brand new stock fuel pump or getting another aftermarket fpr(the one on the car now was sold with the turbo kit) thanks a lot!</TD></TR></TABLE>
no, the stock fuel rail and fpr are actually very well designed.
But it really depends on how much power you are making..
If you are in the 350 + range, then I would get a new FPR
Old Feb 2, 2004 | 11:47 AM
95ONE's Avatar
Default Re: aftermarket fuel pump & fuel pressure regulator help (Lildrgn)
I agree. Don't worry about it. Spend your money somewhere else.
Old Feb 2, 2004 | 01:39 PM
Default Re: aftermarket fuel pump & fuel pressure regulator help (nsxlr8)
cool so i should be ok running the aftermarket fuel pump with the stock fuel pressure regulator and stock fuel rail?
Old Feb 2, 2004 | 06:10 PM
SMOOTH97LUDE's Avatar
It will be fine to keep your stock fpr. But when you need to lower or raise your pressure you will not be able to with the stock fpr.
Old Feb 2, 2004 | 06:32 PM
93hatched_projekt's Avatar
Default Re: aftermarket fuel pump & fuel pressure regulator help (SMOOTH97LUDE)
Your gonna want to dip into your car $$$ and pick yourself a fpr. Your gonna wanna bump it up , you will see better results but a loss in fuel economy , but oh well right. your stock fpr will be fine for now but your gonna want to adjust your pressure in the future.
Old Feb 2, 2004 | 06:38 PM
Default Re: aftermarket fuel pump & fuel pressure regulator help (93hatched_projekt)
Here's a recent thread on fuel pressure for 4th gens https://honda-tech.com/zerothread?id=685846&page=1
Old Feb 2, 2004 | 08:01 PM
thanks, but yeah i dont plan on needing adjustments...im just gonna be running I/H/E with this motor and thats it...
702accord
Jan 20, 2010 09:49 AM
hondaaccord94
Dec 30, 2006 10:14 PM
blkgsr03
Jan 19, 2005 10:25 AM
mdj_ge
Jul 7, 2004 04:08 PM
ddong2lee
Apr 8, 2004 07:36 AM
