Can't Believe.. CEL because of COLD weather??
Old Oct 5, 2001 | 03:01 PM
PiYoImuT's Avatar
Default Can't Believe.. CEL because of COLD weather??
ok.. my CEL is back on..
the same problem like before.. the engine seemed to be very shaking when I first start the engine.. but after a while, it is idle normal again...(but the CEL is still on of course)...
I know it will be gone in a couple days..
From my observation, it seemed that when I start the engine and outside temperature is cold (I think 45-50 F, not sure), the problem arise.
the last 2 week has been very warm (60< F) so the CEL is gone and never come back..
anyone know the probable cause of this? Bad Spark Plugs?
Aleph: I have appointment on Monday with John @ Baierl.. I almost cancelled it thinking that the CEL is gone for good.. I think I will still go AutoX with the CEL..
depending on how warm that day will be.
Old Oct 5, 2001 | 03:12 PM
01ITR#700's Avatar
Default Re: Can't Believe.. CEL because of COLD weather?? (PiYoImuT)
Hmm, are you resetting the ECU whenever you get the CEL? Or does it just go away? But no, air temperature shouldn't set off the light.
M
Old Oct 5, 2001 | 03:16 PM
HX_Guy's Avatar
Default Re: Can't Believe.. CEL because of COLD weather?? (01ITR#700)
Umm...have you checked the code?
Old Oct 5, 2001 | 03:18 PM
PiYoImuT's Avatar
No, I didn't have to reset the ECU.
it will go away after a couple of days...
and, the GAS CAP is tight as H3ll. ok. I even have a hard time to open it.
Last time, I cleaned the injector, the CEL is gone for a while... but that also when the weather becomes warm again.. so I don't know what's going on..
Monday, for sure, I will take it to the Dealer.
Old Oct 5, 2001 | 03:20 PM
PiYoImuT's Avatar
the code? 7-1,7-2,7-3... random misfire on Cylinder 1-2-3..
I let it idle for a while.... then everything seemed to be OK..
VTEC is on.. don't know about 8400 RPM though.. didn't get the chance to try..
and after the engine warmed up, I shut it off, then start again, the engine is fine.
only when cold starting...
Old Oct 5, 2001 | 03:25 PM
01ITR#700's Avatar
Hmm,
I don't get how the CEl light goes away by itself? In my past experience with Honda's and Acura's you can fix the problem the code indicates and the actual Light will not go away until the ECU is reset???
M
Old Oct 5, 2001 | 03:26 PM
HX_Guy's Avatar
Well random misfire can be caused by any of these:
Ignition system, fuel supply system, MAP sensor, IAC valve, contaminated fuel, lack of fuel, fuel injector, fuel injector circuit, low compression, valve clearance
Its really hard to narrow it down. The dealer might be able to pull a more specific code.
Old Oct 5, 2001 | 03:31 PM
PiYoImuT's Avatar
Default Re: Can't Believe.. CEL because of COLD weather?? (HX_Guy)
Yeah, I tried to narrow down the possibilities..
I cleaned the injector, then change gas station for a couple tanks, move the sparkplugs from one cylinder to another, test the plugs cable...
but that's all I can do..
I'll definitely post what the dealer say when I get back from them.
Old Oct 5, 2001 | 03:32 PM
HX_Guy's Avatar
Have you checked your valve clearance? I got the same codes when I first installed my Crower cams. My valves were WAY loose..after I adjusted them it went away.
Something you might wanna try before you go and pay the dealer to scan the code.
Old Oct 5, 2001 | 03:34 PM
Cosworth's Avatar
Cold weathet DEFINITELY effects the CEL. This is due to the cat not warming up properly in most cases. However, it shouldn't occur unless it's extremely cold (below zero degree celcius) outside. It happened to my EK after the car sat outside for a week below freezing point. It took me a good 2 days of normal driving for the CEL to go away by itself. Just makesure to properly warm up your car when it's cold outside.
Old Oct 5, 2001 | 03:35 PM
Chris's Avatar
You shouldnt pay a dime. WARRANTY should cover it.
Old Oct 5, 2001 | 03:39 PM
PiYoImuT's Avatar
Default Re: Can't Believe.. CEL because of COLD weather?? (Cosworth)
Outside is not below 0 yet... but the CEL does go away by itself.. I don't have to reset the ECU.
remember that when I 1st start the engine, it shakes real bad.. I didn't hit the gas or anything.. I want to warm the engine up for a while, but then... CEL blinking..
and stayed on.
um... valve clearance? how do I check it?
Old Oct 5, 2001 | 03:44 PM
HX_Guy's Avatar
If you have a warranty...let the dealer take care of it
Old Oct 5, 2001 | 07:44 PM
Mike K's Avatar
OBD2 sucks. Put a OBD1 clip in there w/ a mapped ECU.
1- no more codes
2- more power
3- worse gas mileage(but who cares)
Old Oct 6, 2001 | 02:16 PM
PiYoImuT's Avatar
TOday, without resetting the ECU or even touching anything, the CEL is gone again. tsk tsk tsk.. what is wrong with my R...
still gonna bring it to the dealer on Monday though...
Old Oct 7, 2001 | 07:36 AM
ZygSpeed's Avatar
Good luck with the codes. /ed
Old Oct 13, 2001 | 08:07 PM
PiYoImuT's Avatar
Default Re: Can't Believe.. CEL because of COLD weather?? (zygspeed)
I took the car to dealer, they have no idea of what's going on..
They said they'll call Acura HQ to ask for similar problem...
Today, while I was preparing my stuff for AutoX,.. CEL is back on!!!!!!!!
and didn't go until now.
the exhaust smell like rubber is burning....(or oil).. and the air flow out from the exhaust is like choking.. burp-burp and the engine sounds like an old VW Beetle.
CEL is 71..(7 long blink and 1 short) Damn!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!
So Again, Random misfire....
[Modified by PiYoImuT, 12:10 AM 10/14/2001]
Old Oct 13, 2001 | 08:12 PM
PiYoImuT's Avatar
OOh.. but since I have to take the car home, I drive slowly..
and managed to go past 6K RPM.. VTEC is on...
but it takes more than 1 minute to go 6K...
(I just want to know whether VTEC is engaging or not)....
Old Oct 13, 2001 | 08:14 PM
GRM Scott's Avatar
25 Year Member
71 is Random Misfire (probable cause according to helm: Ignition System, Fuel Supply System, MAP sensor, IAC valve, contaminated fuel, lack of fuel)
Old Oct 14, 2001 | 07:47 AM
Bert's Avatar
Default Re: Can't Believe.. CEL because of COLD weather?? (Aleph)
Interesting... I have similar problems on my modded GSR. I thought it might be the Todas. I already replaced the plugs, fuel filter and wennt back to the stock fuel pump to no avail. I'm planning on replacing the O2 sensors next as I was running pretty rich for a while.
Old Oct 14, 2001 | 08:14 AM
TurboR1391's Avatar
If you still have a warranty I would definitely take it to the dealership and get them to servive it.
b20acura
Nov 16, 2011 07:20 PM
megaman096
Oct 25, 2004 05:27 PM
95LSS
Mar 7, 2004 11:00 AM
DumpedSi
Aug 20, 2003 03:40 PM
