HELP! car wont start
i have a 92 civic dx with a b18 swap... its been running good for awhile until today... the engine basically wont turn over... i already got my battery changed and checked... i got my starter tested and it is still in good shape... any suggestions are welcome... thanks
if it's not cranking then I would be safe to say that at this point he's not getting any spark either.
Have you tried turning engine over by hand to ensure engine even turns over?
Does your start click once, then nothing?
If so, there's dust in your solenoid, hit it with a hammer, not hard enough to damage it, but enough to move the dust around a bit.
Is your car a manual? If so, can you push start it?
Is your car an auto? Are you sure it's in park or neutral?
I've had to help lots of people with their car that won't start and after a couple minutes realise the gear isn't in P or N, although it looks like it is, wiggle the gear stick a bit.
[QUOTE=ryanstev]
QUOTE]
From my expereinces pushing starting isnt gonna help, its only if the battery is low and has no juice. But give it a shoot cause @ this point you've got nothing else to lose.
QUOTE]
j4s0n1337
41
Feb 19, 2011 07:50 PM
