factory gsr cam center lines?
I'm hoping you guys can help me out. I'm putting together a turbo gsr motor with the factory gsr cams, I'm not sure how much material was shaved off the block and head so I'm looking for the factory centerline or valve opening numbers to set the cams at .
thanks, it was late last night and I didn't do all the reading in the manual, I just looked at the cam spec and only saw totall lift numbers. now i'm off to finish it!
