factory gsr cam center lines?
Old Jan 31, 2004 | 06:13 AM
frisbie's Avatar
Default factory gsr cam center lines?
I'm hoping you guys can help me out. I'm putting together a turbo gsr motor with the factory gsr cams, I'm not sure how much material was shaved off the block and head so I'm looking for the factory centerline or valve opening numbers to set the cams at .
Old Jan 31, 2004 | 06:19 AM
Flamenco-T's Avatar
Default Re: factory gsr cam center lines? (frisbie)
with GS-R cams, there is a hole on your cam plate cover that you can use with a .5mm punch that will line up the cam right at center.
stan
Old Jan 31, 2004 | 06:32 AM
b18bturbo's Avatar
Default Re: factory gsr cam center lines? (Flamenco-T)
its in the helms manual page 6-12 1994-1995 integra service manual
just use the punch stated above that is true center line
Old Jan 31, 2004 | 07:27 AM
frisbie's Avatar
Default Re: factory gsr cam center lines? (b18bturbo)
thanks, it was late last night and I didn't do all the reading in the manual, I just looked at the cam spec and only saw totall lift numbers. now i'm off to finish it!
dc2much
Jan 10, 2010 06:03 PM
92bseries
Feb 23, 2009 10:33 AM
AJxr
Jul 26, 2008 08:53 AM
Copy Cat
Jan 4, 2006 08:40 AM
bluesi00
Mar 23, 2004 10:32 PM
