Running on two cylinders........help.
Old Jan 30, 2004 | 03:24 PM
elwood's Avatar
Default Running on two cylinders........help.
nevermind............
Modified by elwood at 5:27 AM 2/1/2004
Old Jan 30, 2004 | 03:26 PM
JDMlyfestyle's Avatar
ya. get a B series
Old Jan 30, 2004 | 03:57 PM
Riceburner247's Avatar
Default Re: (JDMlifestyle)
Well, was it running fine before you started screwing with it?
Old Jan 30, 2004 | 04:01 PM
elwood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">ya. get a B series </TD></TR></TABLE>
thanks for the bump at least.........i think the z6 was fine
400$ for a complete swap.......yeah, the z6 is fine.
It was running fine before I did the stuff above. It had
a few check engine lights I hadnt fixed yet, but it ran ok.
any help.......thanks
Old Jan 30, 2004 | 09:36 PM
elwood's Avatar
Default Re: (elwood)
anyone else fealing like the civic forum is going to ***** lately?
Old Jan 30, 2004 | 09:39 PM
The Internet Tough Guy's Avatar
yes. i feel the same way. been hanging out elsewhere lately.
i have no idea why you're having this problem, and i know this is a completly retarded suggestion, and i know you're better than this but: do you have the firing order correct
Old Jan 30, 2004 | 09:45 PM
xerox445's Avatar
Default Re: (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">yes. i feel the same way. been hanging out elsewhere lately.
i have no idea why you're having this problem, and i know this is a completly retarded suggestion, and i know you're better than this but: do you have the firing order correct </TD></TR></TABLE>
Yes this place has gone Down Down Down, EG+ is goin down.
On a lighter note, jwn7 is probly right. do you know what 2 cyls are not firing? Are you getting spark on all of them? In the dark, if you crank the car, are the wires arc-ing bad? You could have swaped the 2, and thats why they are not working...
Old Jan 30, 2004 | 09:58 PM
Default Re: (xerox445)
i said that because the last time i changed my cap and rotor, i mixed up cylinders 2 and 3 on the dizzy. the motor started ok, and it did actually run (like crap), but it was shaking like a bitch due to the dual misfire. then i switched them and everything was cool.
Old Jan 30, 2004 | 10:00 PM
xerox445's Avatar
Default Re: (jwn7)
with even one cyl mising, my motor shakes like a mo fo...but that could also be because my mounts are falling out, and my rear tranny mount is cracked on the case...i should get that fixed, huh
Old Jan 31, 2004 | 01:40 AM
elwood's Avatar
well, at least I got some replies this time.
I was positive that I had them right, but what you guys are saying
is giving me my doubts. Its # 2 and 3 that arnt firing. So what is
the proper firing order.........?....I guess I could look in the helms.
Old Jan 31, 2004 | 06:18 AM
2lua's Avatar
you right about this forum go to ****, anyway back to your problem. did you bleed all the air out of your coolant system? check the plug at your dist. to see if you tight?
Old Jan 31, 2004 | 07:08 AM
SOHC_MShue's Avatar
why?
Old Jan 31, 2004 | 10:33 AM
elwood's Avatar
Default Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
why?</TD></TR></TABLE>
because he obviously dosnt know the answer to any of my questions,
and for some stupid reason he decided to ***** my thread.
to all the other sugestions, I dont think its going to be that easy.
I have tried so many things........I am seriously at a loss here.
Old Jan 31, 2004 | 10:54 AM
just go out and try switching them. it's a long shot, but it might work. or look in your helms.
and if that doesn't work: get a b series
sleeplsm
Jul 3, 2007 08:00 PM
k20eg6bk!
May 2, 2007 07:55 AM
E Town DSM
Mar 22, 2004 05:48 AM
crewmember
Feb 13, 2004 04:21 AM
Spade
158
Dec 5, 2003 02:51 PM
