failed inspection
Old Jan 30, 2004 | 01:53 PM
respectblades's Avatar
Default failed inspection
i failed inspection the other day...
i am throwing a cel
intake air temp sensor...
my nox was like 2000
and my hcl was also to high
its a 92 cx..
but i swapped a b16a and i'm running a chipped p28
any one with any suggestions....
other than fixing the light and everything will be alright
i also have 4-1 headers and stock cat .. with a 5 zigen cat back
Old Jan 30, 2004 | 08:36 PM
vtekstorm's Avatar
Default Re: failed inspection (respectblades)
u tried retarding the timing?tuning the ecu to give lower fuel pressure? and change that sensor maybe that might work? and make sure the car is really nice and hot warmed up. put one of those big power fans in front of the car.
hopefully that helps you out good luck
Old Jan 30, 2004 | 09:11 PM
boostn420's Avatar
Your hc's are high because the ecu is chipped. The Nox is probably because of advanced timing. You need to fix the temp sensor, and find a less agressive ecu. Is the header legal, or will they over look it? If there are any exhaust leaks that may cause high Nox too.
Old Jan 30, 2004 | 09:19 PM
Oh Crap's Avatar
yeah, a faulty IAT will cause your car to be excessively lean causing a spike in HC and NOx. Or in some cases it can cause a spike in CO and a drop in NOx. either way borrow or unchip your ecu, and get the MIL (malfunction indicator light(proper term for CEL)) fixed.
Old Jan 30, 2004 | 10:47 PM
bossman032's Avatar
Default Re: (Oh Crap)
jdm b16a all gens motor have hard time passing tell from experience good luck
japan has no emissions soo most off the cars don't run right from the start
Old Jan 30, 2004 | 11:00 PM
boostn420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oh Crap &raquo;</TD></TR><TR><TD CLASS="quote">yeah, a faulty IAT will cause your car to be excessively lean causing a spike in HC and NOx. Or in some cases it can cause a spike in CO and a drop in NOx. </TD></TR></TABLE>
No, if there a check engine light, it usually goes into a rich safe mode. A lean condition wouldnt cause high HC anyway. HC's are caused by unburned fuel, you dont get that from a lean condition.
Old Jan 30, 2004 | 11:04 PM
bossman032's Avatar
Default Re: (boostn420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn420 &raquo;</TD></TR><TR><TD CLASS="quote">
No, if there a check engine light, it usually goes into a rich safe mode. A lean condition wouldnt cause high HC anyway. HC's are caused by unburned fuel, you dont get that from a lean condition.</TD></TR></TABLE>
number of things cause NOX, LEAN is one like brother up said your cooling system not working right, coolant temp sensor has a lot to do with that, your cylinder temp to high are just some causes off high nox.
99% off all JDM b16 have high nox problems its the motor most off the time
also carbon buildup cause high nox also
Old Jan 31, 2004 | 07:38 AM
vtekstorm's Avatar
Default Re: (bossman032)
could your catalytic converter be shot considering your running a rich mixture and have alot of unburnt fuel. because exessive unburnt fuel will ruin the converter.
just another thought
Old Feb 8, 2004 | 09:18 AM
Oh Crap's Avatar
A lean condition will cause high HC, it's called a lean misfire. HC or Hydro Carbons is caused by, yes unburned fuel or misfire. CO is too much gas.
How CO and HC work. If you're running rich, you get high CO and high HC. If you're running really lean you get low CO and high HC. If you're running just right, you should have about .23% or lower CO, and about 60ppm of HC. runnign Lean also causes HIGH Nox cause your combustion chamber gets "hotter", when you're running a lil richer, it reduces NOx, but increases CO and HC a bit. IMO if you use the USDM B16 cam, you just MIGHT have a chance of passing. My 02.
What are the actual readings?
94EJ1Coupe
12
Mar 16, 2008 10:10 AM
JDM_EK4_Coupe
Apr 30, 2007 11:43 AM
LudeJdm
Jun 8, 2006 05:09 AM
97civicdx
Mar 5, 2006 06:00 AM
