what size AN or BANJO fittings to get for SS fuel line?
Old Jan 30, 2004 | 06:24 AM
Nextelbuddy's Avatar
Default what size AN or BANJO fittings to get for SS fuel line?
ok im going to get the SS line and banjo fittings for the fuel line that goes from the fuel filter to the fuel rail. can anyone tell me what size fittings i need to get and what size SS line to get as well?
Old Jan 30, 2004 | 06:28 AM
Flamenco-T's Avatar
Default Re: what size AN or BANJO fittings to get for SS fuel line? (nextelbuddy)
why don't you just buy a kit ?
I do have a compelte kit, it includes a banjo to -6AN adapter for the stock fuel rail.
and for the fuel rail, I'll use this,
teh kit comes compelte with all fittings and adapter to convert your filter and rail to -6An hose assembly.
stan
Old Jan 30, 2004 | 06:36 AM
B18Flip's Avatar
Default Re: what size AN or BANJO fittings to get for SS fuel line? (Flamenco-T)
can i use these with that kit? (the guage )
Old Jan 30, 2004 | 06:39 AM
Flamenco-T's Avatar
Default Re: what size AN or BANJO fittings to get for SS fuel line? (B18Flip)
yes you can, I did it on quickB18B's car, same setup. OR I can also give you the -6An fitting to the fuel rail, but with a 1/8" NPT in the middle for Fuel pressure gauge
stan
Old Jan 30, 2004 | 07:05 AM
i would love to buy your kit but i need the parts for tommorrow. busted fuel lines suck. and the is a shop that i get all my EARLS fitting from down here in atl. could you possibly tell me what the sizes are
also i curretnly have a fuel pressure gauge in my fuel filter just like in that pic above. what fittings do i get to be able to retain my curent B&M fuel pressure guage?
Modified by nextelbuddy at 2:18 PM 3/8/2004
Old Jan 30, 2004 | 07:56 AM
Flamenco-T's Avatar
You need to just run banjo for both the filter and the rail, so you can install the gauge in there.
the banjo fitting is 12mm to -6AN, if you need it overnight with saturday delivery, I can do that so you'll have it tmw if you can't find it local.
stan
atlplayer4life90
Sep 2, 2009 04:30 PM
sk8shorty012
May 6, 2009 12:10 PM
h22sedan
Nov 8, 2006 06:02 PM
D0HC
Dec 19, 2002 01:23 PM
Arturbo
Feb 5, 2002 04:05 PM
