Rod bearing #s and colors
Old Oct 4, 2001 | 06:32 PM
t's Avatar
t
Default Rod bearing #s and colors
What color is the #1 rod bearing? If you have the info please list all the #s to colors. I had this info saved on my computer somewhere but cant find it.
All i know is the colors; blue,black,brown,green,yellow,pink,red.
Old Oct 4, 2001 | 06:56 PM
Mike K's Avatar
Default Re: Rod bearing #s and colors (t)
The fact that it is #1 doesn't tell you **** about what bearing is needed. Get the letter off the appropriate crank journal and match it up on the chart in the Helm's manual. Duhh..
Old Oct 4, 2001 | 08:39 PM
t's Avatar
t
Default Re: Rod bearing #s and colors (Mike K)
Not using Honda rods, I was told they were made for the #3 Honda rod bearing. I am using the helms. thank you
[Modified by t, 9:39 PM 10/4/2001]
Old Oct 4, 2001 | 09:14 PM
sgT's Avatar
sgT
If you are using the Helm manual then you should already know that
you need the number off the rod and the letter off the crank to make
a bearing color.
Old Oct 4, 2001 | 09:20 PM
t's Avatar
t
Default Re: Rod bearing #s and colors (sgT)
Yes, the rod # is 3 and the letter off the crank is w,w,x,x. I know all the bearing colors, but dont know the #s. (not part no. as I know those too.)
I am using the Type R helms manual and the rod # for type R is different than previous Integras. Type R has 21,22,23,24,25,26 for the rod #.
Sgt-You should know this, since you are such a great engine builder. I was hoping for a fast answer from one of you guys, after all, that is what I try to do. But I guess I will have to find some other means to get the answer. Thanks guys.
[Modified by t, 10:21 PM 10/4/2001]
LovinVTEC4
Jun 13, 2007 04:21 PM
jdmhatch94
Sep 13, 2003 02:03 PM
ltho1998
Jul 16, 2003 11:13 AM
LSR 97
Jul 18, 2002 11:07 AM
Brian_92GSR
Apr 2, 2002 01:53 PM
