bought a turbo! not sure what it is???
Old Jan 29, 2004 | 11:47 AM
integracivic94's Avatar
Default bought a turbo! not sure what it is???
as the title says! all i know is that its a garrett and it has a/r 48!!! i assuming this is a t3??? any ideas??? is a/r 48 any good for my d16z6?
Old Jan 29, 2004 | 01:01 PM
Default Re: bought a turbo! not sure what it is??? (integracivic94)
thanks for the help fella's
Old Jan 29, 2004 | 01:02 PM
b18bturbo's Avatar
post some specs pics etc. we can help you out. Just need more than just an ar number.
What abotu exducer inducer specs if you can get that we canhelp you big time easily
Old Jan 29, 2004 | 01:39 PM
Bailhatch's Avatar
Default Re: bought a turbo! not sure what it is??? (b18bturbo)
the A/R of the turbine housing is usually stamped inside the part where the exhaust goes in. The A/r of the compressor cover usually stamped inside the air outlet. Most T3s have a rectangular turbine flange that measures about 2 5/16" X 1 13/16" inside. What car is it from?
.48 is the turbine. will spool pretty fast depending on the wheel size
Old Jan 30, 2004 | 12:18 PM
Default Re: bought a turbo! not sure what it is??? (Bailhatch)
Not sure what the rest of the details are for this turbo as of yet! but thanks for the reply's! the turbo came off of a rover 800! (english car) tried searching for details but didn't have much luck as there is not to many tech sites for these cars! by the way it does have a rectanguler flange!!!! is this turbo likely to last til the redline?
Old Jan 30, 2004 | 12:24 PM
dropgear's Avatar
that's a garret t03 .48, AKA Turbo I. It's ideal for a Honda, and will keep boost until redline no prob. Mid 80's Chrysler's used them as well.
Old Jan 30, 2004 | 12:29 PM
lazerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracivic94 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help fella's</TD></TR></TABLE>
you're welcome
Old Jan 30, 2004 | 12:59 PM
Default Re: bought a turbo! not sure what it is??? (lazerus)
once again thanks fella's! thats good to know cos i got hella cheap and no shaft play either
Old Jan 30, 2004 | 01:05 PM
any ideas what is the most i can get from this turbo???
Old Jan 30, 2004 | 01:14 PM
dropgear's Avatar
In terms of what?
Old Jan 30, 2004 | 01:18 PM
Default Re: bought a turbo! not sure what it is??? (dropgear)
max hp or max psi or when it will start spooling???
Old Jan 30, 2004 | 01:22 PM
dropgear's Avatar
My experience is that it's fully spooled at 10psi by about 4k (D16Y7, w 12:1 FMU). As for max HP, I have no clue. It can handle waaaay more boost than your engine can handle. so really, they sky's the limit
Old Jan 30, 2004 | 01:27 PM
good to thanks man
Old Feb 1, 2004 | 01:03 AM
right i've been lookin at the turbo! and all i can find stamped on the exhaust is .49 on the exhaust inlet! and .48 on the other bit! does this shed any light?
Old Feb 1, 2004 | 08:18 AM
Mad Cow's Avatar
That doesn't really help. Grab a digital camera and take as many closeup pics as you can.
P.S.- I was born in Essex.
Old Feb 1, 2004 | 11:19 AM
Default Re: bought a turbo! not sure what it is??? (MadCow)
Pics will be up 2moro! small world hey madcow! where in essex was u born? where bouts u live now?
notsolfast
Nov 18, 2011 12:23 AM
japanbran
Mar 20, 2007 10:15 PM
TURBO DC2
Mar 28, 2005 07:25 PM
integracivic94
Aug 1, 2004 05:52 AM
_Endless_
Feb 25, 2003 10:39 PM
