VTEC Solenoid Valve?
Old Oct 4, 2001 | 02:50 PM
SonicDark's Avatar
New User
Default VTEC Solenoid Valve?
Well the code that Acura pulled is 1259 and they ordered a VTEC SOLENOID VALVE to replace it. I'm going to be going to the track this weekend.....safe to run the car or not? What does it do?
There we go
[Modified by SonicDark, 4:09 PM 10/4/2001]
Old Oct 4, 2001 | 02:53 PM
hybrid_eg's Avatar
Default Re: VTECH Solenoid Valve? (SonicDark)
i'm sure you'll be ok.. worst thing that would happen is that would have "VTEC".. remember its VTEC not VTECH lol!
Old Oct 4, 2001 | 03:04 PM
98TypeR's Avatar
Default Re: VTECH Solenoid Valve? (hybrid_eg)
we should put a banner up there to remind them its vtec and not vtech, or people are going to put them in their place.
Old Oct 4, 2001 | 04:00 PM
Black SVT's Avatar
Default Re: VTECH Solenoid Valve? (98TypeR)
He is talking about his cordless phones guys.C'mon get with the program.
Old Oct 5, 2001 | 08:28 AM
SonicDark's Avatar
New User
Default Re: VTECH Solenoid Valve? (Dc2k-specR)
Anyone else?
Old Oct 5, 2001 | 09:33 AM
STOLEN - ITR 98-0652's Avatar
Default Re: VTEC Solenoid Valve? (SonicDark)
Safe? - probably yes... but you'll be choking the car at high RPMs with just the low cam. I would not track the car until the issue was resolved... less for safety as much as the power loss.
Do? - the VTEC solenoid activates the oil flow to activate the rocker pin, thus switching to the middle HI cam during high RPM operation. It is an essential part of the VTEC system (thus, the code).
Old Oct 5, 2001 | 10:10 AM
J Ritt's Avatar
Default Re: VTEC Solenoid Valve? (ITR 98-0652)
If you are still having problems with VTEC after this is replaced, try the oil pressure switch. I had to have mine replaced.
Old Oct 5, 2001 | 10:13 AM
B18CXr's Avatar
If VTEC is not working properly...........rev limit will be droped and CEL should be lit.
Old Oct 5, 2001 | 11:44 AM
J Ritt's Avatar
Default Re: VTEC Solenoid Valve? (J Ritt)
Jack,
Not necessarily. On my car, the car would keep revving over the VTEC switch point, but it just wouldn't kick in. It would sporadically kick in during the upper rev range. Also, no CEL.
Old Oct 5, 2001 | 11:53 AM
B18CXr's Avatar
Point taken:
but,
If you have: 1) VTEC controller equipped car 2) USDM motor 3) fully fuctional VTM sensor then, if the solenoid is pulled "on" and the VTM doesn't see pressure, at least code 22 will be thrown and a lower rev limit will be issued.
If, for instance, your low on oil and the x-over is sporadic, then yes the ecu will not throw the code and lower limit or CEL.
Old Oct 5, 2001 | 12:01 PM
J Ritt's Avatar
Default Re: VTEC Solenoid Valve? (B18CXr)
right. The dealer actually replaced my computer before they tried the solenoid valve or the pressure switch. I argued with them relentlessly to check these first, but they insisted on the computer. Oh well I figured, it's free. Of course I was right...
Dontoh
16
Jun 21, 2012 08:21 PM
Stevemyster
May 16, 2011 12:45 PM
Midori Green
May 7, 2008 07:10 PM
the.hamburglar
Jul 15, 2007 04:59 PM
HU MAN CHU
Jun 29, 2006 09:43 PM
