intercooler piping --2.5" or 3"
Old Jan 28, 2004 | 07:53 PM
2ltrsnailpwr's Avatar
Default intercooler piping --2.5" or 3"
If i can fit 3" piping under the hood is it worth while?? am i selling my self short by going with 2.5" intercooler piping or is that the going size??Set up has full potential of 600+ hp ..lay down words of wisdom BTW i did search this topic and cant find any info on it ..thanks
Old Jan 28, 2004 | 08:41 PM
shermanyang's Avatar
Default Re: intercooler piping --2.5" or 3" (2ltrsnailpwr)
i would just stick with 2.5" piping. 3" IMO is overkill. however, i've seen people do 2.5" from turbo to FMIC and then 3" from FMIC to TB to reduce pressure drop.
Old Jan 28, 2004 | 08:55 PM
JM Performance's Avatar
Default Re: intercooler piping --2.5" or 3" (shermanyang)
for 600hp...then i would go with 3" but are you really gunna run 600hp? if not then the larger piping will hurt, not help.
Old Jan 28, 2004 | 09:03 PM
SpdFrk's Avatar
The most i'd ever go is 2.75" unless this is going to be a full all out drag car pushing over 750whp.
Old Jan 28, 2004 | 10:47 PM
V-SPEC 1's Avatar
Default Re: intercooler piping --2.5" or 3" (SpdFrk)
I'd stay at 2.50
Old Jan 28, 2004 | 11:06 PM
TurboTony's Avatar
Default Re: intercooler piping --2.5" or 3" (boostedb20vtec)
i would stay with 2.5", plus i 've heard smaller piping is better for a bigger turbo. It makes it spool up fast because your forcing more air flow in it. The bigger piping gives it to much room and does not get fulled. But like I said I do not know if its true, its what I heard.
Old Jan 29, 2004 | 12:50 AM
Tad's Avatar
Tad
Default Re: intercooler piping --2.5" or 3" (TurboTony)
def 2.5
i'm no expert but 3" would be ridiculously thick,
I highly doubt your running the kind of massing hp setup that would warrant that.
remember this isnt cold air intake piping your working with here,
its charge piping
Old Jan 29, 2004 | 06:35 AM
Decent input...thanks tad & 00silverls(sarcastically) i didnt just pull the 600hp figure out of my *** ...and when it comes to racecars ive seen a fair share of them running 3" aluminum pipe.
Old Jan 29, 2004 | 06:37 AM
Jdm93civic's Avatar
i would think that having a smaller piping would spool up a little faster....
Old Jan 29, 2004 | 06:40 AM
b18bturbo's Avatar
Default Re: (Jdm93civic)
i would stick with 2.5 inch for your street setups keep it simple
95civlx
Jun 1, 2010 09:37 PM
ThePro
Oct 26, 2004 11:12 AM
integranator
May 12, 2003 05:15 AM
internet ay
Aug 2, 2002 07:11 PM
