Short shifter and boot??
Hey i was wondering if anyone had a kit or know of a shift boot kit with or without **** that would go on a 92-95 civic hatch with a short shifter? I want a kit that dosnt show any of the shifter at all. I mainly want no metal showing so no one knows i have short shifter and so it is connected to my shift ****.
any help would be greatly appreciated
I just fixed mine so that there is no gap...
I have an Edelbrock short shifter with a Skunk2 shift **** and a CTR shift boot. I put a big thick rubber band around my short shifter near the top so it holds the boot up!
That way it doesn't slip down and expose the shifter. It works really well and holds the boot up nicely!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koreanwilcox »</TD></TR><TR><TD CLASS="quote"> I put a big thick rubber band around my short shifter near the top so it holds the boot up!
i did the same to mine its works just fine
That way it doesn't slip down and expose the shifter. It works really well and holds the boot up nicely!!</TD></TR></TABLE>
My setup looks the same with a Solo short throw and the CTR boot and I had a little gap. What I did was cut the threads off and retheaded it. Now it is a short shifter as well.
hmm, that top one looks great, but it doesn't look too "short" here is mine... i have no idea what shifter it is, as the shop that i got my auto-5speed done at put it on there after they broke my oem one
edit, sorry it's blurry, it's the best i have
edit2, here is a better one i found.... my boot actually stays up over the shifter now, just not in these pics.
vou could try to rig up an accord shift **** and boot cause the boot actually clips onto the ****. If youre going for oem look thats probably the way.
on my shift boot i rolled the inside at the top a little and zip tied it on the inside. since the shifter tapers down the zip tie cant slide down and the shift boot stays tight up against my **** but that might just be my boot that could be rolled i dont know how urs looks
