fuel switch? (56k)
I've decided to put a safety fuel switch in my car. not only for the safe part but more specifically thieves. Im trying to locate the wire in which to spice. is this the correct one?
i cant tell which wire that is but i think its the yellow with black line...i already forgot
is your hatch going to stay stripped like that? if so i would think it would be kind of hard to hide the switch
fuel cut off switch = awesome cheap mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X-Static »</TD></TR><TR><TD CLASS="quote">i cant tell which wire that is but i think its the yellow with black line...i already forgot
is your hatch going to stay stripped like that? if so i would think it would be kind of hard to hide the switch</TD></TR></TABLE>
Umm its my project drag car, so ya its staying stripped. And its yellow w/red wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X-Static »</TD></TR><TR><TD CLASS="quote">you positive??? im pretty damn sure is yellow w/ black..</TD></TR></TABLE>
i meant the wire shown was yellow and red. And if its not the right thing, were can i find the right wire?
it should be in that same wire loom...what year is your hatch? my rex is a 90..dunno if 88-89 was different, but i dont think it was.
i dont recall seeing more than one yellow wire in there tho, maybe it just looks red?
is the yellow wire coming out of the fuel pump side of the harness yellow w/ red too?
dude, thats the fuel guage sender. the fuel pump is under the other black thing, near the drivers side rear wheel well.
cut into where you pointed and you just made a great fuel level cut off switch!
btw, i recommend that you cut into the main relay end, its the same wire but closer to the front, where youd probably have your switch, and less obvious. better yet, remove the yelow/black #7 terminal from the main relay plug, which is a male spade plug, then you can make a non-permanent splice into the system using a female spade plug, wire that to the switch, then use either your own constructed end terminal using a normal spade plug, or get a spare from the junkyard to plug right back into the stock plastic plug. wrap some electrical tape and its totally hidden, and reversible since you didnt have to destroy the wiring harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIMPIN »</TD></TR><TR><TD CLASS="quote">^^ didnt understand that myself.
Im looking to do a kill switch. So the yellow black wire is under that silver cap?</TD></TR></TABLE>
its not under it...it comes out from the side of it....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Custom Rex »</TD></TR><TR><TD CLASS="quote">could someone give better details on where this wire actually is and what color it is for a 1990 crx si....</TD></TR></TABLE>
should be yellow w/ black line, and i think it runs all the way from your main relay to the fuel pump...it runs along the driver kick panel through the door seal, back to where the fuel pump is shown in the red hatch on the first post...it can be tapped into anywhere in between but it may be a little tricky to get to in some spots..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">
the wire is under the FUEL PUMP COVER.</TD></TR></TABLE>
ah, so thats were that yellow/black wire is....no wonder i couldnt find it
http://www.courtlukens.com/cutoff_switch.htm
This should help you guys, not sure if the wire colors are the same on EF's though but you get the idea.
yeah i found that site in my search and the colors on there are yellow and green i believe...the EF color is yellow and black..everything else, atleast for me, was the same concept.
itsJDMyo
16
Jul 20, 2004 06:25 AM
