Cant start car after distributor got wet
Old Jan 28, 2004 | 05:29 PM
h23vtec_dc2's Avatar
Default Why are preludes so hard to sell???
also, i sorta got my distributor wet, and now i can't start it.. is it because of that??? i took the cap off and on the bottom inside the cap was sorta wet, and had little oil.. wiped it down and all. still doesn't start.. is it the cause of the cap and rotor getting wet?
Old Jan 28, 2004 | 06:26 PM
LudeyKrus's Avatar
Does it turn over but just won't crank, or what?
Old Jan 28, 2004 | 06:49 PM
Default Re: (LudeyKrus)
it cranks and everything, but sounds as if it's not getting any spark
Old Jan 28, 2004 | 07:24 PM
SKDRCR's Avatar
Default Re: (h23vtec_dc2)
maybe you f$%ked up your ignitor,
take the dizzy cap off and use a hair drier or something
to dry everything up and then try starting it up again
Cottonwoodz's Avatar
Lightly spray WD-40 in and around the cap, wipe and let dry..
Old Jan 28, 2004 | 08:05 PM
TruNinja619's Avatar
Default Re: (Cottonwoodz)
clean off all the crap thats in there... i remember mah old auto shop teacher tellin me... whenever u pressure was ur engine.... to make shure to clean out the distributor cap....
Old Jan 29, 2004 | 06:42 AM
Sephro's Avatar
Default Re: (TruNinja619)
Take Cottonwoodz advice for the cap. If the actually interior parts of the distributor got wet I would take it off the car ASAP before it has time to dry and sink it in distilled water. Make sure you wash the whole thing out so everything gets good and wet from the distilled water. Now take it out of the distilled water and let it dry. This will save your electronics if they are not already blown.
Old Jan 29, 2004 | 02:51 PM
Default Re: (Sephro)
so if it take the cap off, clean it with water, and completely dry it off it'll still work?
Old Jan 29, 2004 | 05:20 PM
britishlude's Avatar
No Man : Don't use water if anythin a water removal spray as already suggested like wd 40 and then wipe it and let it dry, you need any dampness right out totally. Distilled water is still water but without impurities, I think the guy who advises water meant distilled spirits surely ?
Old Jan 30, 2004 | 12:47 PM
Default Re: (britishlude)
funny thing is.. one day it'll start. then the next it wont at all.. yesterday i cleaned it out, and it's starting fine now. but i'm thinking maybe the next day or something it might not start. but ill let you all know. thanks for all your help
Old Jan 30, 2004 | 03:23 PM
Is the dist cap free from any hairline cracks, and are the contacts for the rotor arm all clean & in good condition ? Worth checkin next time it lets you down, but if you've got it starting ok now don't disturb it.
Old Jan 31, 2004 | 05:45 PM
okay just what i thought. i tried starting it up again today. and it didn't start.. wtf?? im thinking it might also be because of the gas?? i bought it from a junkyard and thinking maybe the gas is old(gas light is also on too). think thats it?
Old Jan 31, 2004 | 05:58 PM
yellow_jacket's Avatar
Hard to say. Next time it won't start pull a plug. Check to see if it is fuel soaked. Check to make sure you have spark. It's a littlehard to tell you what is wrong without knowing basics like that. If it is something intermittent it may be a bad connection somewhere. My sisters Civic did the same thing, turned out to be a bad coil. You just need to figure out what you are losing. Spark or fuel.
Old Feb 1, 2004 | 02:09 PM
Default Re: (yellow_jacket)
yea i dont know what the hell it is. cause i started it back up again.. dude it's hella gay.. right now just too broke to go out and get new cap/rotor, and gas. but any other suggestion would help. thanks
KaBlookie
Apr 24, 2007 01:26 PM
Japanese1.6
Apr 10, 2005 08:42 AM
SI_niki
Jun 15, 2004 07:54 AM
2camsaam
Oct 3, 2002 12:34 PM
