Leaking hatch
Hey guys, i have a 92 hatch and it leaks water pretty bad. The other day i opened up the hatch and there was a little puddle in the back, and when you look at the driverside tail light from an angle you can see water floating around in there... I was just wondering if you guys could give me an idea of what to use to seal it up and where exactly to do so at... Thanks
check what these guys said,and also maybe pull out the taillight and make sure the foam gasket that seals it to the body is still good.
chris
chris
dth0ng69
Nov 23, 2009 01:54 AM
EL Vap133
Jan 5, 2006 07:03 AM
