H22 swap axle problems
Old Jan 28, 2004 | 08:53 AM
matix's Avatar
Default H22 swap axle problems
I just got my h22 swap done. I already screwed up my axles i think. I went under car and saw grease slung everywere. I had a stage 3 clutch put in my car with the swap. Do you think the hard catches of shifting gears screwed up my axles or was it the shop that did the swap.I was maybe thinking the accord axles cant handle the h22 with a stage 3 clutch. If thats the case i was looking at the high performane axles from the driveshaft shop. Please help dont know what to do.
Old Jan 28, 2004 | 01:54 PM
tiaccordsh's Avatar
Default Re: H22 swap axle problems (matix)
accord axles should handle it just fine assuming you dont have any amazing modifications. It sounds like the boot was already ripped either ahead of time, or by the shop, or just from wear.******* up a brand new axle shouldnt result in a tear in the boot. I assume you are using the axles that were already in yer car before the swap?
Old Jan 28, 2004 | 01:57 PM
Accord97Racer's Avatar
Where did you get ur h22... email me... werides@aol.com.. Thanks..
Old Jan 28, 2004 | 02:09 PM
Accord94DX's Avatar
Default Re: H22 swap axle problems (Accord97Racer)
use the accord axles and intermediate shaft. the prelude ones are bit too long and will bind and **** up. this is speaking from experience
Old Jan 28, 2004 | 07:55 PM
matix's Avatar
Yea the boots are ripped. I ordered new axles. thanks. Oh tia i like the obd2-obd1 conversion havnt seen that much.
ricedaccord
Jun 16, 2011 01:12 AM
Rheg6
May 31, 2011 02:14 PM
Blue94Accord
Aug 16, 2010 12:03 AM
hondah23eg
May 27, 2008 06:09 PM
MugenAccordSedan
May 28, 2004 10:11 PM
