H22 swap Axles problem
Old Jul 15, 2010 | 11:55 AM
Blue94Accord's Avatar
Default H22 swap Axles problem
Hey I have a 94 accord. swapped in an H22 and wanted to use the prelude axles. I thought i seen many times that you can use both sets of axles as long as you have the matching halfshaft.
The prelude axles seem longer on the end where the nut goes then the accord. so the whole axle is still a little loose after nut is on.
Any solution?
I tired to use a washer but it still seems loose a little bit
Old Jul 15, 2010 | 02:33 PM
extralargenog's Avatar
Default Re: H22 swap Axles problem
Any solution?
Ya go get a big washer that clears the oputer edges of the splines on the axles. Ive been using OEM prelude (either H23 or H22 will bbe the same) on my 650+WHP CD5 for 3 years now and have only had to change 1... ANd it didnt brake I was just lazy and didnt feel like changing the boot...
LOL.
Do the washer. Needs to be about .100 to .125 thixck and youll be golden... IIRC its ONLY on the PAss side.
Old Jul 15, 2010 | 06:12 PM
cool so i wont have to worry about the driver side then?
Old Jul 19, 2010 | 09:34 PM
slo2k's Avatar
i used a axle washer off a gxp grand prix. used burr bit and angled inner hole on one side. won't take much.
Old Aug 16, 2010 | 12:03 AM
I needed a washer on both sides
ricedaccord
Jun 16, 2011 01:12 AM
Teddieb15
Nov 30, 2008 05:04 PM
hondah23eg
May 27, 2008 06:09 PM
H2Os
Apr 27, 2006 06:02 AM
kurt.
Sep 1, 2002 02:32 PM
