Too Much Oil
When I had my oil changed, it looks like they put in about one quart too much. Will this harm the engine or cause any problems? I drove it about 50 miles before I checked it.
Thanks,
d9h
Thanks,
d9h
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjason »</TD></TR><TR><TD CLASS="quote">YES! it will hurt your car....its almost as worse as having really low oil.
Exactly..drain the oil and put the proper amount in quickly
</TD></TR></TABLE>Exactly..drain the oil and put the proper amount in quickly
No..it should be fine....It's like drinking lots of beer.....Yea you may over drink sometimes but is it always that bad?..And sometimes you can get a good buzz off drinking loads of beer and start to have a good time...
couple reasons.
it creates more oil pressure, which can blow seals and gaskets out.
in some cases, if the oil pan gets filled, the crank actually has to travel through oil.
...and allmotordc5booya,
this isn't a good way to start out on this board
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller »</TD></TR><TR><TD CLASS="quote">
I agree
</TD></TR></TABLE>I agree
interestingly, 3.0-3.2 M3's are commonly overfilled by about a quart for track use. High-G sweepers tend to uncover the oil-pickups.
But I don't think Honda's like being overfilled.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorDC5erBooyah! »</TD></TR><TR><TD CLASS="quote">No..it should be fine....It's like drinking lots of beer.....Yea you may over drink sometimes but is it always that bad?..And sometimes you can get a good buzz off drinking loads of beer and start to have a good time...</TD></TR></TABLE>
You can't be serious............
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzzz »</TD></TR><TR><TD CLASS="quote">interestingly, 3.0-3.2 M3's are commonly overfilled by about a quart for track use. High-G sweepers tend to uncover the oil-pickups.
</TD></TR></TABLE> Hmmmmm....I'd think the real solution to this would be an oil pan with better baffleing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller »</TD></TR><TR><TD CLASS="quote">couple reasons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">If its high enough for the crank to dip into the oil, it churns it up into a foam. Then your oil pump will start picking up air along with the oil.</TD></TR></TABLE>
thats what i was going to say
They oil for those is also about $46.00 a quart
</TD></TR></TABLE>They oil for those is also about $46.00 a quart
I am a girl and I know that too much oil is bad for any car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blondeaccord »</TD></TR><TR><TD CLASS="quote">
OWn3D allmotordc5erboo-toomuchoil-ya
This is correct:
this isn't a good way to start out on this board </TD></TR></TABLE>
</TD></TR></TABLE>OWn3D allmotordc5erboo-toomuchoil-ya
This is correct:
Draggin99Si
Jun 15, 2007 09:34 PM
GoLowDrew
Jul 31, 2006 07:10 AM
kegard
32
May 30, 2005 12:12 AM
