Speedometer Problem. VSS?? (yes, searched)
Old Jan 27, 2004 | 11:11 PM
tzenisj's Avatar
Default .
Old Jan 27, 2004 | 11:16 PM
743power's Avatar
Default Re: Speedometer Problem. VSS?? (civic_rice)
my speedometer will completely stop working if I am doing between 40 and 55 mph. I can do any other speed and I am fine, but if I'm doing 45, it will stop working. I just have learned to live with it. If I look down and my speedo isn't working, than I know I'm doing 40-50.
As for your problem, check for a loose connection on the VSS connector. Black connector on top back of your tranny.
Old Jan 27, 2004 | 11:22 PM
743power's Avatar
Default Re: (civic_rice)
http://www.acuraparts247.com/s...ch=no
it's the part with a dotted box around it on the top right. If you have a manual tranny, it will be the only sensor on the top of the tranny. The reverse sensor is on the front lower part of the housing.
Old Jan 28, 2004 | 03:52 PM
ruthless013's Avatar
yes, and it is most likely a result of the loose connection. it's easy to get water in there.
Old Jan 28, 2004 | 04:01 PM
eg_nezay's Avatar
Had the same exact thing, I changed my harness and fixed the problem.
Mostly likely if a loose connection didnt fix it, the actually harness is corroded.
Go to your local junkyard or if you have a buddy that has a spare engine harness and cut the SSV harness.
Soldering it would be best, but if you dont have access to that, just color match the wires and use electrical tape.
Old Jan 28, 2004 | 04:04 PM
743power's Avatar
Default Re: (eg_nezay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_nezay &raquo;</TD></TR><TR><TD CLASS="quote">
Soldering it would be best, but if you dont have access to that, just color match the wires and use electrical tape.</TD></TR></TABLE>
At the VERY least, use solderless connectors. Electrical taping wires that are exposed to vibration and heat/moisture is just asking for a bad connection.
Old Jan 28, 2004 | 04:11 PM
eg_nezay's Avatar
Default Re: (743)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">
At the VERY least, use solderless connectors. Electrical taping wires that are exposed to vibration and heat/moisture is just asking for a bad connection.</TD></TR></TABLE>
No problems after 6months
Old Jan 28, 2004 | 04:35 PM
GRAVEDIGGER's Avatar
fuses??
Old Jan 28, 2004 | 05:09 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_rice &raquo;</TD></TR><TR><TD CLASS="quote">okay i think i might have found the problem... hahaha
i took off the VSS (Vehicle Speed Sensor) and in between the pin and the hole for the pin on the VSS thinger, there was a dead moth/bee insect type thing that fell out of it..
i'm assuming that is at least part of the problem.
im curious about the harness though.. where does the harness on the VSS run to?? how expensive is a replacement?</TD></TR></TABLE>
VSS is connected to engine harness. It's like $350 discount price from the dealer for an eg/dc. if its a vtec model car, you can find a used one for $100-200 asuming its an eg/dc or $150-300 for a vtec model EK.
Old Jan 28, 2004 | 05:17 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_rice &raquo;</TD></TR><TR><TD CLASS="quote">oh god. i don't have 100+ to spend on harnesses.
what can i do to make do with my stock wiring if that is the problem?</TD></TR></TABLE>
you can go to a junkyard and cut the sensor off another car and solder it onto your harness. that's most likely not the problem. Just check to make sure your wires are going into the plug tightly.
Old Jan 28, 2004 | 06:07 PM
dogfood's Avatar
junkyard, ebay
Old Jan 28, 2004 | 06:12 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_rice &raquo;</TD></TR><TR><TD CLASS="quote">ok i took the vss apart... its just a bunch of black grease and a little cylendar type bearing that spins around with a spring on the bottom.
What's the 'sensor' part of this thing? what type of grease is this.. anyone know of a vss rebuild?</TD></TR></TABLE>
Thats all connected to a gear inside your tranny. The gear spins at the same speed as the axles, and it sends the signal to the ecu. Theres nothing more to the "sensor" than what you see.
Old Jan 28, 2004 | 06:49 PM
hndakd's Avatar
Default Re: (743)
just so i dont have to start another thread i got a couple questions...
my vss just went out to, i tried cleanin it and everything but it is dead. volt meter said .02 and i read it was supposed to pulse at 5 and get to as much as 12.
anyways im ballin on a buget and want to know if a d series vss will fit on a b series. i have a b18c, i think i can get a d series one pretty easily and more importantly cheaper.
Old Jan 28, 2004 | 10:58 PM
eg_nezay's Avatar
Default Re: (743)
VSS is connected to engine harness. It's like $350 discount price from the dealer for an eg/dc. if its a vtec model car, you can find a used one for $100-200 asuming its an eg/dc or $150-300 for a vtec model EK. </TD></TR></TABLE>
$350? I didnt tell the guy to buy an ENGINE harness, I told him to buy just the harness(clip).
That should be like $5 from a local race shop that has messed up harnesses laying around.
Old Jan 28, 2004 | 11:05 PM
eg_nezay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_rice &raquo;</TD></TR><TR><TD CLASS="quote">so how would I go about trying to rebuild it?? (take all the crap out, clean it, re grease it) perhaps?
i have it apart, it looks disgusting.. i just need to know what type of grease?</TD></TR></TABLE>
I dont know why you took it apart, its not a rebuild kind of thing.
You said the speedo went up and down sometimes, if it didnt move at all, I would say its the VSS.
You should ask a buddy of yous to let you borrow his to see if just in case its the VSS, if that doesnt work, change the harness. Liquid in the harness or outside the harness causes corrosion, defecting the readings for the wires.
Old Jan 28, 2004 | 11:07 PM
743power's Avatar
That should be like $5 from a local race shop that has messed up harnesses laying around.</TD></TR></TABLE>
Are you talking about just replacing the VSS connector on the engine harness?
Old Jan 28, 2004 | 11:09 PM
eg_nezay's Avatar
Default Re: (743)
Yes, just the harness that has 3 wires and clips into the VSS.
Its very easy to get water in there since its facing up, cleaning your engine for example, casuing corrosion.
Old Jan 28, 2004 | 11:20 PM
eg_nezay's Avatar
My harness clip looked perfect when it got replaced, looks have nothing to do with it when its eletrical, unless of course its noticeable from the outside.
Old Jan 29, 2004 | 09:08 AM
My car acted the same way and it turned out o be the VSS fuse located under the dash.
Old Jan 29, 2004 | 09:20 AM
HNDAPWR's Avatar
Default Re: (GRAVEDIGGER)
Sounds like either the magnet or the speed cup in the speedo are going bad. We fix them all the time.
Old Jan 29, 2004 | 12:15 PM
Snail Tuning's Avatar
Default Re: (HNDAPWR)
also check the plug on your alternator. my speedo wouldn;t work, but everything else in the dash worked fine. make sure the green alternator plug is clean and pushed all the way on. also search under my name. i did a big write up on the 92-95 civic speedo. diagrams of the wires and everything.
Old Jan 29, 2004 | 12:19 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Also try packing the plug with a little bit of Vasoline or dielectric grease.
That's if the plug and/or connector looks a bit corroded.
As far as the VSS goes, any 1992-1995 Civic, 1994-1998 Integra (maybe even newer) will all work the exact same.
I seriously doubt anyone here needs a new harness of any sort. The problem will be the sensor, the connection, or the fuse.
Old Feb 2, 2004 | 08:04 PM
Independent's Avatar
I am experiencing the same problem even after replacing the sensor itself. Thanks for all the help
I have heard that this is rather common on SOHC motors...
Old Feb 16, 2004 | 11:51 PM
EG TYPE-R's Avatar
well i had a very similar problem as your recently. mine would bounce around a little or get stuck sometimes or not even read anything. I don't know if its the same thing but i replaced the entire gauge cluster for other reasons (tach) and now i don't have any of the previous problems. i think that my speedometer must have been going bad somehow. anyways maybe try looking into a speedometer problem if your vss checks out to be all good.
good luck
misha
gabriel0830
May 17, 2013 01:29 PM
strykr89
Sep 15, 2008 08:03 PM
johnjjy
Jan 14, 2006 02:02 AM
JDMtype Eg6
Jul 29, 2005 02:17 PM
92LudeSI
Dec 10, 2003 07:24 AM
