clutch release noise? help
Old Jan 27, 2004 | 10:52 PM
Tokyo_X-treme_Racer's Avatar
New User
Default clutch release noise? help
2 days ago my clutch began making noises after you release it. is this normal or is it a sign that the clutch is wearing out. Please help.
Old Jan 27, 2004 | 10:54 PM
screech's Avatar
Default Re: clutch release noise? help (Tokyo_X-treme_Racer)
what kind of noise cuz if its a squeak mine and my friends civic both do it.
Old Jan 27, 2004 | 11:01 PM
New User
Yes it does make a squeak noise and I don't recall it making that noise after clutch release? Is this normal?
Old Jan 27, 2004 | 11:03 PM
Spartanic's Avatar
Default Re: (Tokyo_X-treme_Racer)
It could be the throwout bearing wearing out and may need replacement. While your at it you might as well replace the clutch pressure plate and clutch discs as well.
Old Jan 28, 2004 | 04:03 AM
JimmyAtlantis's Avatar
Default Re: (Spartanic)
Holy trying to get this guy to spend his money, Batman! You say noise from your clutch, but I'm assuming you mean clutch pedal. And you say after you release it. Did you mean when you're releasing it? If it's just the clutch pedal, it's nothing to worry about. It's just a spring doing it's work. If I assumed incorrectly, I apologize.
Old Jan 28, 2004 | 07:30 AM
BauleyCivic's Avatar
Risky Business
Default Re: (JRI94)
Is it like a squeak or stiffness when you press/release the clutch? or is it a clicking noise when the clutch is let up?
Old Jan 28, 2004 | 11:12 AM
New User
Default Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Is it like a squeak or stiffness when you press/release the clutch? or is it a clicking noise when the clutch is let up?</TD></TR></TABLE>
Yes thats it, what you said. Car still drives normally, just that the sqeaky noise just all of a sudden began after a few days ago.
Old Jan 28, 2004 | 11:16 AM
monicle's Avatar
It could either just be a squeaky pedal or you need to take the boot off of the clutch slave cylinder and grease up where it touches the fork. Id bet on the second.
New User
Default Re: (JRI94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 &raquo;</TD></TR><TR><TD CLASS="quote">Holy trying to get this guy to spend his money, Batman! You say noise from your clutch, but I'm assuming you mean clutch pedal. And you say after you release it. Did you mean when you're releasing it? If it's just the clutch pedal, it's nothing to worry about. It's just a spring doing it's work. If I assumed incorrectly, I apologize.</TD></TR></TABLE>
Yes, it's after I release the clutch pedal.
Old Jan 28, 2004 | 11:18 AM
POE's Avatar
POE
whenever i press my cluth in all the way it makes a sqeaky noise also..but it has been like this for 1 year now
Old Jan 28, 2004 | 11:19 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tokyo_X-treme_Racer &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, it's after I release the clutch pedal.</TD></TR></TABLE>
What kind of noise is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx &raquo;</TD></TR><TR><TD CLASS="quote">whenever i press my cluth in all the way it makes a sqeaky noise also..but it has been like this for 1 year now</TD></TR></TABLE>
This is normal. Dont worry about it.
Old Jan 28, 2004 | 11:20 AM
POE's Avatar
POE
This is normal. Dont worry about it.</TD></TR></TABLE>
cool.. just wondering do u know what it is making that noise bauley?
New User
Just a squeak noise right after I release clutch.
Old Jan 28, 2004 | 11:21 AM
New User
Default Re: (Vtecin94dx)
So you've never had a problems with taht squeak noise?
Old Jan 28, 2004 | 11:22 AM
Risky Business
cool.. just wondering do u know what it is making that noise bauley?</TD></TR></TABLE>
Its the spring for the clutch pedal...I took mine to the honda dealer...they said nothing was wrong but lubed it up anyway...still makes the noise when its cold out sometimes...but its fine
Old Jan 28, 2004 | 11:24 AM
New User
Its the spring for the clutch pedal...I took mine to the honda dealer...they said nothing was wrong but lubed it up anyway...still makes the noise when its cold out sometimes...but its fine </TD></TR></TABLE>
Where I live it has been raining and quite chilli. Maybe I just have to lube mine up.
Old Jan 28, 2004 | 11:28 AM
day1si's Avatar
The clutch pedal on every singal Honda I have owned has done that.
No worries, just the spring from what I can tell, although on my 00 Si I did get a free CC out of it!!!
Old Jan 28, 2004 | 11:35 AM
Risky Business
Where I live it has been raining and quite chilli. Maybe I just have to lube mine up.</TD></TR></TABLE>
Yeah if your problem is just a squeak when you press in or release the pedal dont worry about it
Old Jan 28, 2004 | 11:48 AM
POE's Avatar
POE
allright cool thanx bauley like always
LandeZak
Sep 9, 2013 10:38 PM
victor.m
Apr 4, 2009 09:19 PM
JamesV
Dec 1, 2005 06:35 AM
jbsmith
Aug 29, 2005 12:21 AM
