tell me what's wrong with this honda......
There's this civic eg that has a b16 delso vtec motor in it.......it's running a p28 ecu
When vtec hits the rpm go up and down and there's no vtec kick....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekstorm »</TD></TR><TR><TD CLASS="quote">are u low on oil?</TD></TR></TABLE>
This is the most likely problem. VTEC will not engage unless there is sufficient oil pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">
This is the most likely problem. VTEC will not engage unless there is sufficient oil pressure.</TD></TR></TABLE>
im not sure this would cause the RPM's to go up and down tho..
mike
mike
