f22b dohc??
ok i have done a search and sorta got an answer but here are my questions. I will soon be buying a f22b DOHC that will be going into a 1992 accord 4dr ex(5 speed)and i just wanted to know what is the best ECU to use on that motor..... i dont really care about gas i just want to go fast. Also should i leave the setup of the ecu as obd1 or do the conversion to obd2. And my last question is can i swap a h22 head on to the f22b block? (just in case some day it pops up for a good price!!!)
If you can get a JDM chip that is best but difficult to find. i believe that you can send your chip to have it remapped to H23 specs which will be as close as it gets here. JDM f22b is obd1.
The frankenstein F22/h22 is a bit of a pain from the searches I had checked out, and unless you are very very experienced in swaps and engine work, it may not be the best route.
If you don't care about gas mileage, you can put in the JDM f22b and then boost it with 1g DSM injector/ic and manifold. manifold needs redrilling on a couple bolts to mount it, but it lines up perfect. That should give you a pretty quick setup for not too much. dunno how dependable it will be, however.
Good luck.
Good luck.
