obd1 h22 in 96 accord help ?
Old Nov 20, 2003 | 03:42 PM
racerboyb18c1's Avatar
Default obd1 h22 in 96 accord help ?
urg wont run with the h22 obd1 ecu , but will with the accord ecu , im using a jdmhondaparts jumper.
Modified by racerboyb18c1 at 8:20 AM 11/21/2003
Modified by racerboyb18c1 at 6:53 PM 11/21/2003
Old Nov 20, 2003 | 09:05 PM
Default Re: obd1 h22 in 96 accord help ? (racerboyb18c1)
bump please
Old Nov 20, 2003 | 11:09 PM
aeolus's Avatar
Tell us more about the wiring and what was done to it to make it work.
Old Nov 21, 2003 | 09:50 AM
Default Re: obd1 h22 in 96 accord help ? (aeolus)
its a obd1 motor in a 96 obd2 car, the wires were redone to make the distributer work also it runs fune with the accord ecu perfect in fact, i purchased an obd1 conversion harness from jdm honda parts and it will not run with the obd1 h22 ecu it barely idles then if you touch the gas it dies .
Old Nov 21, 2003 | 10:06 PM
bump before bed
Old Nov 21, 2003 | 10:16 PM
IN VTEC's Avatar
Any codes?
I've used a JDM P13 Auto ECU in a OBD-2 Accord H22 swap before and it ran....but with a flucuating idle that I never got around to figuring out before the owner threw a rod in it.
Old Nov 21, 2003 | 11:24 PM
aeolus's Avatar
Default Re: obd1 h22 in 96 accord help ? (IN VTEC)
i say try another conversion harness,if the f22 ecu works,im willing to bet the conversion harness has some bad or wrong connections.
Old Dec 1, 2003 | 06:34 PM
no codes just pain in the but still not working
bayhtwe
Mar 4, 2011 05:33 AM
h222accord92
Aug 8, 2007 12:10 PM
petrojdmcd5
Apr 5, 2006 10:25 PM
racerboyb18c1
Nov 21, 2003 10:05 PM
racerboyb18c1
Nov 21, 2003 09:51 AM
