red heat sheild sleeves, or any heat sheild sleeves to protect oil and water lines????
Old Jan 27, 2004 | 06:48 PM
Snail Tuning's Avatar
Default red heat sheild sleeves, or any heat sheild sleeves to protect oil and water lines????
what is that red heat sheild tube that most cars in magazines use?
i need something to protect my oil inlet and water lines for my turbo.
any sejetsions and where can i buy that red tube heat shield stuff at?
Old Jan 27, 2004 | 07:38 PM
Default Re: red heat sheild sleeves, or any heat sheild sleeves to protect oil and water lines???? (jz)
i checked my summit catalog, nothing their.
i remeber seeing a site that sold the red sleeves they were like 2500 degree resistant, summit sales these slip stainless covers but their only like 700 degree resitant.
anyone know what the red ones are called or where to buy them?
thanks
Old Jan 27, 2004 | 09:09 PM
skrewdlude's Avatar
Default Re: red heat sheild sleeves, or any heat sheild sleeves to protect oil and water lines???? (bmcc72)
maybe this stuff? http://store.summitracing.com/...=1883
Says it goes up to 2k :/
Old Jan 27, 2004 | 09:29 PM
redboost10's Avatar
Default Re: red heat sheild sleeves, or any heat sheild sleeves to protect oil and water lines???? (skrewdl
is that needed for ss oil lines?
Old Jan 28, 2004 | 01:19 AM
NJIN BUILDR's Avatar
Just a comment on "fire sleeve"and "heat sleeve" type shielding.I've see it used on wiring and ignition wires.The sleeving will take the heat,but it doesn't reflect the heat,and cooks everything inside.You probably need something more like stainless shields with air gaps to deflect the heat.
Glenn
laloquera916
Jun 9, 2015 04:30 PM
s2k_3.11
Nov 30, 2006 11:39 PM
redboost10
Mar 17, 2004 08:15 PM
J T*
Jul 27, 2002 05:28 PM
