********URGENT*********
Old Jan 27, 2004 | 06:41 PM
birz's Avatar
Default ********URGENT*********
Ok,, I'm about to buy some Ross pistons, my question is wich set should I buy???
#pn 99808 BORE:3.209 STROKE:3.504 DISH CC:-11.9 WEIGHT:310 C.H.:1.180
OR-------------
#pn 99807 BORE:3.209 STROKE:3.504 DISH CC:-6.1 WEIGHT:289 C.H.:1.180
My setup is B18B1 (stock) T25 turbo at 8psi, 2.5 mandrel downpipe/exhaust, GSR tranny, SMC+ fuel hack, 450cc DSM injectors, MSD BTM to retard timing. I think that's all the useful info. The main concern is the CR, I have calculated the CR on C-speedracing website and the #99808 yielded 8.1cr and the #99807 yielded 8.89cr. but on the Ross calculator it's different, wich one gives the most accurate results?? I'm planning to go 10psi at the most, so wich set should I take and what CR is the real one?
The deal is like tomorrow so I really need to know quick please.
Thanks alot guys for helping me out.
Old Jan 27, 2004 | 06:44 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: ********URGENT********* (birz)
way to low............................
Old Jan 27, 2004 | 06:48 PM
birz's Avatar
Default Re: ********URGENT********* (HybridcivicLS-T)
wich set I should take, it's not too low,, I mean the stock comp is 9.2:1, so 8.89:1 is not that far,, but the thing is HOW accurate is the calculator? are you telling me to take the 99807?
Old Jan 27, 2004 | 06:53 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by birz &raquo;</TD></TR><TR><TD CLASS="quote">wich set I should take, it's not too low,, I mean the stock comp is 9.2:1, so 8.89:1 is not that far,</TD></TR></TABLE>
not to far..........................MAJOR DIFFERENCE
Old Jan 27, 2004 | 06:56 PM
tony1's Avatar
I'd go with the 99807's, they're work good for a street car.
Old Jan 27, 2004 | 07:22 PM
birz's Avatar
Default Re: ********URGENT********* (tony1)
thanks alot,,, it's street use so it should be perfect,, thanks again
Old Jan 27, 2004 | 07:23 PM
birz's Avatar
thanks to be so useful HybridcivicLS-T
Old Jan 28, 2004 | 04:23 AM
birz's Avatar
any other opinions?
Old Jan 28, 2004 | 04:29 AM
RGAZ's Avatar
New User
A DSM t25 on a B18?? Are you kidding?? Can you say **choke*** Choke***!! Man that turbo is way too small for a b18. Geez, do a search for how to read a compression map. I bet the power will take a huge nosedive at about 4,500 rpm since the turbo will be adding bukoo heat to the charge.
2nd, I personally think that if 10 psi is the MAX you will run, I would go for 9.0:1 or even 9.5:1 compression. Anything under 9:1 will be a dog until boost hits.
You can go with the 8.8:1 choice but plan on running 13-15 psi minimum or you will not be happy.
Randy
Old Jan 28, 2004 | 05:19 AM
birz's Avatar
Default Re: ********URGENT********* (RGAZ)
The sutep has been running all the summer last year,, and ther was no choke or whatever,, the power curve was pretty good, that was on the stock block. I know it would be better a T3t04 but hey! can't afford it. I'm satisfied eith the power that gives me that turbo for the moment,,, maybe I'll switch it in the far future.
Old Jan 28, 2004 | 05:21 AM
BoostedsiR's Avatar
well just go with the highest compression possable, but why do you have that little t25 and you want to do pistons. Maybe Im confused hhhmmmmm................
Old Jan 28, 2004 | 05:24 AM
birz's Avatar
Default Re: ********URGENT********* (BoostedsiR)
cuz my current stock pistons are gone,,, and I'm building for the future
Old Jan 28, 2004 | 12:59 PM
birz's Avatar
finally I went with the #99807
thanks for the help
accord2nrz
Apr 17, 2007 06:15 PM
acman1
Apr 30, 2003 05:31 AM
civicfreek
Nov 2, 2002 01:15 PM
xci_ed6
Oct 5, 2002 01:57 PM
Accord94DX
Aug 22, 2002 09:32 AM
