help-code 7
Old Jan 27, 2004 | 03:51 PM
civic88's Avatar
Default help-code 7
I am getting code 7(throttle angle sensor) on my 88 civic 1.5 with dpfi. Can I fix the sensor or do I have to change throttle body? If I have to change throttle body where can I find one?
Old Jan 27, 2004 | 03:54 PM
redlinetuning's Avatar
Default Re: help-code 7 (civic88)
you mean the TPS (throttle position sensor) .. you can take the tb off and unscrew the two small screws.. junk yards sell them for fairly cheap. just grab 2 or 3 ..
any tps from a honda/acura will work. good luck.
if the car has rough idle, jumps up and down then it's your TPS... if not, just take it off and clean it out first.
Old Jan 27, 2004 | 03:58 PM
civic88's Avatar
Default Re: help-code 7 (redlinetuning)
88 civic's don't have a tps they a throttle angle sensor that doesn't unscrew.It's rivited in .
Old Jan 27, 2004 | 04:02 PM
you can still use a dremel and cut the rivet. then use a flathead to get it off. trust me, i have a 90 civic 4spd manual.. i've changed that out too.
Old Jan 27, 2004 | 06:08 PM
civic88's Avatar
Can you replace the rivets with screws?
Old Jan 29, 2004 | 05:53 AM
yeah you can.. the rivets actually have thread on them if i remember correctly. just take the rivets to a hardware shop and match the thread pitch and you'll be fine.. i don't remember the size. sorry
Old Jan 29, 2004 | 07:03 AM
mmuller's Avatar
Mad Scientist
you can also go to the dealer and buy a tps from a 929rr switch the wires and you are good to go
edit:dont know if the 929 will work since the tps for dpfi's is different than 92-up
Modified by mmuller at 11:18 AM 1/29/2004
TASAuto.com
Performance
Jul 19, 2009 05:35 PM
cazper8890
Mar 2, 2007 08:25 PM
nutball72
Nov 11, 2006 07:14 PM
Redsim
Jun 11, 2003 09:37 PM
Inaniac
Oct 21, 2002 12:34 AM
